It's alive...with 6 codes!
Old Jun 4, 2007 | 04:00 PM
MisterB's Avatar
Question It's alive...with 6 codes!
1991 Pickup v6 2wd auto 180,000 mi.
Just replaced;
Timming belt
Belts
Water pump
Thermostat
Pulleys
Front main seal
Power steering rebuild
Plugs
Wires
Cap
Rotor
The truck was running perfect before I got into it...now she is throwing all sorts of codes. CEL 12 22 25 26 and OD 62 63
I have been searching the forum but do not know where to begin. Suggestions would be great!
Old Jun 4, 2007 | 04:10 PM
chrishf12's Avatar
the fsm would be the best help idk if you already have it but here it is.
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Jun 4, 2007 | 04:12 PM
gametom's Avatar
once you look them up in the fsm here's one for a 93 http://personal.utulsa.edu/~nathan-b...fsm/index.html
Start with the lowest number first and work your way up one code at a time
Old Jun 4, 2007 | 04:13 PM
gametom's Avatar
Beat me to it hu Chrish
Old Jun 4, 2007 | 04:22 PM
chrishf12's Avatar
my bad! lol make sure u clear the codes to make sure there arent any old ones stored
Old Jun 4, 2007 | 04:37 PM
MisterB's Avatar
I pulled the EFI fuse twice and let it sit for a few minutes, all codes still there.
Would air in the cooling system be capable of causing the CEL 22?
During the install I started the truck with the radiator out of it and the trans cooler lines shot tranny fluid all over the driveway. Did I damage the solonoids?
After thinking about it for a while I did not set the timming yet. That may explain the code 25 & 26.
I am going to replace the cap and rotor again. I recall starting the truck with the cap loose and it may have damaged the points.
Old Jun 6, 2007 | 03:57 PM
MisterB's Avatar
Update!
Re-burped and got quite a bit of air out of the system. I also added a little bit of tranny fluid (Honda ATF) all I had.
How could doing these two things eliminate 12 25 26 and 62?
Now I have a CEL 22 and OD 63 Advice?
Old Jun 6, 2007 | 07:14 PM
tombothetominator's Avatar
Hey! That's my line!
Hope you get the final few codes figured out.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
