Motor smothering down
Old May 30, 2007 | 01:26 PM
Robrt32's Avatar
I don't really know how to explain this, may be why i couldn't find anything in the search but my truck 92 22RE runs fine at idle but sometime not all time when i'm taking off kinda fast after i shift from 1st to 2nd and push the gas it seems like the moror will bog down. I can let up off the petal and it will speed up.. Does not do it everytime but will do a couple times everyday.. Any ideas?... no check engine light, 28-30 mpg
Old May 30, 2007 | 01:36 PM
TNRabbit's Avatar
I wonder if you have a TPS going bad...not sensing the correct throttle setting & going haywire for a second....
Old May 30, 2007 | 01:44 PM
KegKiller's Avatar
Mine does the same thing every morning at exactly the same time on my way to work. After that it's fine all day
Old May 30, 2007 | 01:59 PM
TNRabbit's Avatar
If it only does it when it's cold, I'd bet your cold start injector is going bad.
Old May 30, 2007 | 02:05 PM
Robrt32's Avatar
I know my cold start injector is bad.. I have to use either in the winter.. Mine does it when its warm.. Ive never noticed it in the mornings when i take off
Old May 30, 2007 | 03:07 PM
Dogsofjune's Avatar
I'm curious about this as well. My '92 has the same symptoms, hot or cold.
Old May 31, 2007 | 03:01 AM
Robrt32's Avatar
Bump it back up, in case somebody missed seeing it
Old May 31, 2007 | 06:21 AM
gametom's Avatar
mine has the same symptoms but it is in a warm start condition and i'm only getting 14-16mpg
Old May 31, 2007 | 02:21 PM
Robrt32's Avatar
So is this something you have to just live with on some yotas? There seems to be several of us with simular problems..
Old Jun 1, 2007 | 04:19 AM
gametom's Avatar
i have brought my truck to a stealership they told me leaky injectors and that it needed a tune up. the cap plugs wires and rotor have less than 30k on them and everything is ome so even the dealer is unsure of the problem
i Will find the problem
Tom
Old Jun 1, 2007 | 08:11 AM
Robrt32's Avatar
I'm like you , I know all my plugs and wires are good.. I have not been long ago worked on my injectors.. I don't believe thats it either.........
Old Jun 2, 2007 | 12:15 AM
gametom's Avatar
my latest thought is the fuel pressure regulator. i don't have a pressure gage but i am going to try to track one down this weekend. the resining i have for this if it is stuck the pressure may be to high and there for dump added fuel into the cylinders flooding it
Old Jun 2, 2007 | 03:02 PM
notanymore's Avatar
not really sure but if its cutting out when you step on it couldnt that be the fuel filter? just a thought of something to look at
Old Jun 2, 2007 | 03:35 PM
CyMoN's Avatar
I have a similar problem when it is cold in the morning also get a stumble when it is raining out or high humidity right after it rained I was thinking it might be my MAF.
I have new cap,rotor and wires & plugs and it is still running funny
Old Jun 2, 2007 | 03:47 PM
gametom's Avatar
my fuel filter is about 2 weeks old so it's not that and my original was fine but you only can tell after you take it off
Old Jun 2, 2007 | 03:52 PM
86toysr5's Avatar
test your ignitor mine had similar symptoms when it was bad expect it was random times not cold or hot
Old Jun 2, 2007 | 10:43 PM
gametom's Avatar
i'm not sure what you mean by ignitor can you clarify
thanks
Old Jun 8, 2007 | 11:52 AM
CyMoN's Avatar
your igniter coil is the thing that provides spark to the distributer
cars-guy
Aug 16, 2020 06:59 AM
okamikai
Apr 30, 2018 10:19 PM
Flossy
Aug 5, 2015 05:14 PM
msane99
Jul 17, 2015 10:13 AM
