Bad Radiator symptoms...?
Old May 30, 2007 | 08:41 AM
jriebe's Avatar
Hi,
I have been through the gamut trying to get my 1986 PU with a 22r to stop running hot. I have adjusted the timing, the valves, changed spark plugs, wires, distribtuor, ajusted the mixture on the carb, changed the fluid out of the radiator, put in a new thermostat and replaced the head gasket and water pump. And yet...despite my efforts, the thing still heats... It runs a consistent 220-230 degrees after about 8-10 minutes of running.
I m now considering the idea that it might be a bad radiator..simply because I have no idea what else could cause the problem...my question is, what are the symptoms and how can I check the thing to see if it is bad without going to a shop?
Thanks for the input...
Jon
Old May 30, 2007 | 08:44 AM
rdlsz24's Avatar
Check out this thread: https://www.yotatech.com/forums/f115/temp-difficulties-116333/
He was having a similiar problem to you and it turned out to be his radiator.
Rob
Old May 30, 2007 | 12:56 PM
jriebe's Avatar
Originally Posted by rdlsz24
Check out this thread: https://www.yotatech.com/forums/showthread.php?t=116333
Rob
Thanks for the info...we'll see what I can find out...
Jon
jasonty
41
Dec 23, 2018 01:00 PM
Road Bull
Oct 10, 2015 04:55 PM
Poncho0206
Jul 10, 2015 06:21 PM
horunner1x
Jul 10, 2015 06:33 AM
Avenged
Jul 9, 2015 07:55 AM
