Replacing Ring and Pinion
Old Jun 3, 2007 | 12:51 PM
scenarioL113's Avatar
I have a 95 runner that has a V6 rear end in it. I need to replace the ring and pinion.
The job is being done by a friend of mine (yes he has done them many times before).
I just need to pick up the ring and pinion and I am considering buying a set of YUKON gears.
What else do I need to do the job. I see the R+P companies offer different kits i.e. "basic kit", or the total kit which is like $200.00.
What do I need to do the job?
Thanks
Frank
Old Jun 3, 2007 | 12:56 PM
olharleyman's Avatar
Get the complete install kit with new bearings I just did mine this weekend and it well woth getting the total install kit with bearing and a solid sleve
Old Jun 3, 2007 | 12:57 PM
JamesD's Avatar
Get ahold of this guy: http://www.gearinstalls.com/index.htm
Old Jun 3, 2007 | 07:20 PM
InternetRoadkill's Avatar
Not sure what's in a 95, but you may want to get the solid spacer and shim kit instead of the crush sleeve for the pinion. It makes setting up the new gears a lot easier.
Old Jun 3, 2007 | 08:47 PM
tc's Avatar
tc
It's called a Master Install Kit. The Genuine Gear ones from 4WP are actually quite good with grade 10 bolts and Timken bearings. Solid spacer/shims are probably a good idea.
bigjstang
Jun 2, 2025 03:56 PM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Edionne13
Jul 9, 2015 01:59 PM
