Knock sensor signal ?????
Old Apr 2, 2008 | 02:24 PM
swerks's Avatar
Question Knock sensor signal ?????
Im getting a CEL for knock sensor signal, my engine seems to be running fine. what does this all mean? should I just replace my sensor. what am I risking if I ignore it for awhile?????
Old Apr 2, 2008 | 05:24 PM
toyota_mdt_tech's Avatar
Big chore, assuming your sig line is correct, yours will be under the intake manifold. Dont even think of doing it without replacing the wire also (short pigtail). Its almost alwasy the connector (corrosion) and sometimes the wire in the harness, but never seen a bad knock sensor yet.
Old Apr 2, 2008 | 06:08 PM
swerks's Avatar
what happens if I dont fix it ??????
Old Apr 2, 2008 | 07:33 PM
dcg9381's Avatar
Retarded timing.. How retarded isn't likely known.
Less power for sure, worse mileage.. Very retarded timing = high EGTs, but it depends on how much the ECU is allowed to back the timing down.
Old Apr 3, 2008 | 05:56 AM
swerks's Avatar
Can I just replace the wire??? I only get the CEL very intermittantly. I reset and it takes days and sometimes weeks before the CEL returns.
Old Apr 3, 2008 | 06:40 AM
dcg9381's Avatar
S, If you had a 22R series with a damaged wire / connection - I'd say yes.. I don't know what the particular problem is with the V6, other than I know it's a PITA to get to...
Old Apr 3, 2008 | 10:12 AM
swerks's Avatar
Sorry, this is for my 86 turbo I should have mentioned that.
Old Apr 3, 2008 | 11:10 AM
dcg9381's Avatar
So is your wire bad? Is it disconnected at the connector?
You can just replace the wire - but it may be a shielded wire (like coax) - let me know and report back.
Old Apr 3, 2008 | 01:47 PM
swerks's Avatar
Ok I need help! I thought I new where this sensor was at but I cant seem to find it ???? Is it near the distributer??? To top it all off while investigating I found a large tear in my CV boot grease everywhere!!!
Old Apr 11, 2008 | 06:09 AM
Team420's Avatar
it is under the intake, you have to take the upper plenum off then remove the manifold, it will be right there, do yourself a favor and replace the sensor too, i made the mistake of not getting the sensor(just did the wire), and now after all that work i still get the same code!! The first time you get into it, it will b a apain in the butt, and prob take several hours, but after you figure out all the shortcuts it shouldnt take more than 4-5 hrs...goodluck
Old Apr 11, 2008 | 08:13 AM
dcg9381's Avatar
Steve has a 22RTE. It's 9:30 relative to the oil filter.
djohnson13
Sep 4, 2015 12:35 PM
raptor510
Aug 19, 2015 02:15 PM
Flossy
Aug 5, 2015 05:14 PM
nonstop
Jul 24, 2015 06:29 PM
