Driveline clunking sound?
Old Apr 5, 2008 | 03:09 PM
atatoy's Avatar
I just replaced the rear u-joint on my 93 4x4 pickup. I thought that would have solved my intermitent clucking sound in the driveline. The other joints seem solid. Could it be the steady bearing. It does have alot of play in it.
Thanks
Old Apr 5, 2008 | 03:13 PM
TOYOTA 1's Avatar
steady bearing? do you mean carrier bearing? posibly that. check for pinion play in the rear end! could be rearend going out.
Old Apr 5, 2008 | 03:14 PM
Luvmeye22re's Avatar
Check the torque on that big nut holding the drive flange to the rear end. It can cause some scary sounds.
Old Apr 5, 2008 | 03:55 PM
thook's Avatar
I don't know how you "inspected" the other u-joints, but you can't really tell the true condition unless you've pulled the driveshaft down and can manipulate the joints by hand. A seizing u-joint can feel solid with the driveshaft still in place. And, a seizing u-joint can cause clunking.
Old Apr 5, 2008 | 06:30 PM
just a 22re's Avatar
thook X2 mine were good it clunked then it poped and there went by drive shaft and after taking it off it had a locked u-joint that would have poped to so take her down man check it out and since you took it down now check them bolts on the rear end and the transfercase
Old Apr 5, 2008 | 07:18 PM
thook's Avatar
x2 Allan....
Old Apr 6, 2008 | 04:08 AM
atatoy's Avatar
I will take the shafts out again and check the trasnfer case and rear pinion bolts also. Hopefully its just a seized u-joint. Will keep you posted. Thanks
Old Apr 6, 2008 | 08:11 AM
atatoy's Avatar
Do I feel foolish! While under the truck I noticed the right side sway bar link had seperated from the lower A-arm. The sound I was hearing was when the end of the link would slip back in the hole. Sorry for the confusion. Now I have to find a good deal on new links, Thanks
runnygirl19
Nov 19, 2015 11:39 PM
altydog
Sep 20, 2015 07:37 PM
potatopants
Sep 15, 2015 06:26 AM
djpg2000
Sep 7, 2015 10:36 AM
