I need to retard ign timing? Proper way?
Old Apr 3, 2008 | 09:25 AM
MulletMan's Avatar
What is the proper way to adjust timing on my 94 22re? Im sure there probably a plug I gotta un do or a jumper wire to connect? Which direection do I turn the dizzy to retard it? Im getting a ping going up hills. Sorry Im new to the toyta scene.
Old Apr 3, 2008 | 10:03 AM
DCYota's Avatar
Jump TE1 and E1 in the diag. box. Set up your timing light...you should be able to hear the idle drop when you jump the connectors. Rev the engine a few times and wait for it to get to operating temp. Turn the dist. away from you (clockwise) to retard timing.
Old Apr 3, 2008 | 11:10 AM
dcg9381's Avatar
Note, do this with a timing light. Don't just crank the timing back. A little turn = a lot of timing decrease and you can have other issues if you crank back too much timing.
Old Apr 3, 2008 | 11:14 AM
MulletMan's Avatar
dum question but where is diag. box located? Yeh I got the timing light ready. Oh what is the "factory setting" degrees?
Old Apr 3, 2008 | 05:11 PM
DCYota's Avatar
Factory setting is 5* BTDC for the 22RE... The diag. box is located on the passenger fenderwell right near the battery. You should have a large engine bay fuse block (somewhat L shaped), right next to that is a small box that should say "diagnostic" on it.
That is, if it's the same as my 88 model 22RE engine bay...I believe it is.
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
