Headlight woes
Old Apr 3, 2008 | 07:59 PM
yarosig's Avatar
Headlight woes
Here's the problem low beams work perfect, high beams only work on flash mode. I have taken apart the column and cleaned out the combo switch. I switch on brights, the light on the dash lights up, but the headlights die. I've been trying hard to fix this problem but cannot figure this one out.
Old Apr 3, 2008 | 08:21 PM
myyota's Avatar
Helps to know what kind of truck you have ?, have you checked the headlight relay ?, they can go bad and cause the problem your having.
Old Apr 3, 2008 | 08:24 PM
yarosig's Avatar
89 4runner 22re. Where is the relay located?
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
