89 22re 4runner died and started
Old Mar 31, 2008 | 02:27 PM
eightnine's Avatar
Hey everyone, my truck died on the side of the road today while i was driving very slowly (probably around 20km/h). It just stalled and wouldnt start. It would crank but nothing. I ended up calling a tow truck after trying to start it for 20 minutes and brought it to my mechanic. Once the truck got there it started up no problem?! Anyone ever experience this before? Im worried now because i dont know if it will die on me again in the future with no warning. I think it might be the alarm system that i have because it stops the fuel pump from working when someone tries to steal it.
Old Mar 31, 2008 | 04:22 PM
eightnine's Avatar
bumpp
Old Mar 31, 2008 | 04:24 PM
scuba's Avatar
if thats what you think
you could have a short
Old Mar 31, 2008 | 04:45 PM
eightnine's Avatar
I'm not sure though, its just a thought..
Old Mar 31, 2008 | 07:01 PM
eightnine's Avatar
any other ideas?
Old Apr 1, 2008 | 05:43 AM
eightnine's Avatar
bumpp
Old Apr 1, 2008 | 05:50 AM
mr_schuster's Avatar
Possible coil or ignitor. My Camry, use do do that crap when it was hot. It needed a coil. ???
Old Apr 1, 2008 | 06:08 AM
NwRunner's Avatar
i had the same problem with my Honda, died on the freeway at 60MPH.... i let it sit and it started 10 minutes later. Replace the Coil.
Old Apr 1, 2008 | 06:34 AM
eightnine's Avatar
I think its a fuel related problem because it felt like the gas ran out as it studdered a bit. Then when i tried to start it again it felt like it didnt have enough gas. Third time i tried it just cranked but nothing.
Old Aug 21, 2008 | 08:55 PM
fireman1559's Avatar
hey im having the same problem except my truck didnt start back up. did you ever get it fixed?
Old Aug 21, 2008 | 09:01 PM
4Crawler's Avatar
My '85 did that once about 10 years ago after spending a week and a half in a shop. Drove about 30 minutes and everything just cut out. Pulled over and checked every fuse (pulled them out to visually and electrically test each one). Found nothing wrong and then tried the starter and it fired back up and has not done that again. I suspect it was some oxidation on one of the fuses or the fuse block and just pulling and replacing them may have cleaned the connections enough to return to normal.
Old Aug 23, 2008 | 01:46 AM
4wheeler808's Avatar
CHECK THE EFI MAIN REALY AND CONNECTING RELAY AND ALL THE CONNECTORS LEADING TO THE FUEL PUMP........
IT HAPPEN TO ME BEFORE..........THE THING JUST DIE OUT WHILE I'M DRIVING.........LATER ON AFTER DIAGNOSING..........I FOUND OUT THE CONNECTOR UNDERNEATH THE CARPET BY THE PASSENGER SIDE...THE FUEL PUMP WIRE(its blue with red stripes on it) is loose...........
i just went clean and repair........no more problem after that............
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
camdenbuck
Jul 7, 2015 07:33 AM
ibayne
Jun 26, 2015 06:30 AM
slider417
Jun 22, 2015 10:18 AM
