Should I Fix It?
Old Apr 3, 2008 | 12:24 PM
Kinked's Avatar
Should I Fix It?
Hey, Just bought my first Toyota,.... got rid of a blazer for it... anyways, had it for about 2 weeks or so and the 5th cylinder blew... fixing it is way beyond my small mechanic knowledge...the mechanic says its a rebuild at about $7500, its got 297k on it... is it worth doing a full rebuild.. or should i risk just fixing the one cylinder?
please help... i want this truck to work
Old Apr 3, 2008 | 12:30 PM
bigarms23's Avatar
you might do a motor swap but i don't know what year or engine you have if its the 22re than just have the cylinder rebuilt if its a 3.0v6 than a motor swap to either a 3.4toyota v6 or a 4.3chevy v6
Old Apr 3, 2008 | 12:31 PM
Kinked's Avatar
its a 91 V6, auto
Old Apr 3, 2008 | 12:34 PM
olharleyman's Avatar
Now Is The Time To Do The 3.4 Swap Better Motor , Mpg And Hp
Old Apr 3, 2008 | 12:36 PM
4bytruckin's Avatar
that was is way too much for a motor swap. Was it a dealer price? at most maybe 2500 for a newer engine. look into a rebuild kit from engnbldr or even lc engineering it's definitely worth the learning experience
Old Apr 3, 2008 | 12:44 PM
Must be a 3.0 he said #5 cylinder is gone
ENGINE SWAP AT THIS POINT MAKES MORE SINCE
Old Apr 3, 2008 | 01:02 PM
Elvota's Avatar
$7500 is extreme for a rebuild... so by those numbers, it is not worth doing a rebuild.
Get some other mechanic's opinions in your area. Could you also define "5th cylinder blew" please? Is that your opinion or the mechanics?
  • If you love the 4Runner, swapping in a 3.4 is the best thing to do.
  • If you like the 4Runner, swapping in a 3.0 in good condition is the best thing to do.
  • If you can't do either of the above yourself, and have to pay for labor, then just driving the 4Runner as it is and shopping for a new one is the best thing to do.
Who knows... maybe you'll loose one more cylinder and be down to a 4Banger. Those are way more reliable anyway.
Old Apr 3, 2008 | 03:48 PM
Kinked's Avatar
Really when it comes to the inner workings of the engine i don't know much... the cylinder is only putting out 30 lbs of pressure on a wet test... and can someone tell me more about this 3.4? if its better i might look into it.
cheers
Old Apr 3, 2008 | 04:07 PM
Elvota's Avatar
https://www.yotatech.com/forums/f160/
Old Apr 3, 2008 | 04:20 PM
SEAIRESCUE's Avatar
Get a friend and pull the motor. Take it to a shop and have it overhauled. Contact Enginebuilder for the costs of a rebuild kit to keep the shop honest. Have the shop install the timing belt and new oil and water pump. With a good mechanic friend, you 2 can do it for less than $2000, maybe closer to $1500 if the shop can just install new rings and knurl the pistons. Obviously, mark everything that is disconnected and take lots of photos.
My $0.02
Old Apr 3, 2008 | 04:22 PM
HERE IS AN AD I FOUND ON THE BANNER ON THE HOME PAGE FOR TOYOTATRUCKPARTS.COM MIGHT HELP YOU IF YOU DECIDE TO KEEP THE 3.0. IT IS THE MIDDLE AD ON THE BANNER IF YOU WANT TO FIND IT. YOU CAN GET ONE OF THESE A FIELD SERVICE MANUAL AND PUT THE PARTS ON THIS LONGBLOCK FROM YOUR MOTOR AND SAVE A HUGE AMOUNT OF MONEY OVER THE $7500 THE MECHINIC QUOTED YOU AND LEARN A BIT ABOUT YOUR MOTOR AND WORKING ON YOUR TRUCK. JUST A OPTION FOR YOU TO LOOK INTO
Toyota Engine 3.0L 3vze v6 Long Block 1988-1995
SAVE $$$. This new reman engine fits 88 thru 95 Toyota pickups, 4 Runners with a 3vze 3.0 v6. engine. This is a factory built assembly line unit with new componets. The engine comes in longblock form with timing components, oil pump and complete gasket set for installation. This engine will carry a factory backed 2 year/unlimited mileage parts warranty covered nationwide. Yes, 2 years! This engine is sold exchange, a REFUNDABLE CORE DEPOSIT of $500.00 will be added to the final sale price. Your core must be turnable for core credit. Core is crank, block, heads, and any part of. A.P.R will pay the return shipping and will refund your core deposit on return of your old engine. Buyer pays flat $250.00 for shipping and delivery. ADD $75.00 IF SHIPPED TO A HOUSE! Once you have installed your new engine, just put your old in engine back in the shipping container, call us, we send a truck to pick it up (no charge) and your core deposit is refunded back to you on return arrival of your good core. This is the same engine we supply Toyota dealers and professional installers nationwide. Thanks,
Cost: $1,795.00
Old Apr 3, 2008 | 04:35 PM
MonsterMaxx's Avatar
Do the swap to 3.4
Old Apr 4, 2008 | 01:11 PM
Kinked's Avatar
thanks for all your help, i'm looking into the 3.4, if i can get one i'll do it
Old Apr 4, 2008 | 01:27 PM
bigt's Avatar
theres a few members from british columbia they should be able to point you to a shop that could get a jdm turbo diesel or 3.4 swap done
Old Apr 4, 2008 | 03:22 PM
Kinked's Avatar
If anyone knows any that won't kill me with cost... that'd be great
crammit442
7
Nov 29, 2017 12:30 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
hollypots
North Carolina
13
Aug 31, 2015 04:08 PM
izzmee
Aug 17, 2015 10:20 AM
lectric80
Aug 11, 2015 12:02 AM
