Timing chain tensioner
I am replacing the head on my truck 1988 22re and I was wanting install the front cover and then the cylinder head,but I'm not sure how to keep the chain tensioner from extending all the way out? Has anyone done this before and have any advice? Can this be done?
You'll want to put the head on first and then install the timing chain before you put the cover on. But, to secure the tensioner, wrap some electrical tape around it while you have the tensioner dampener compressed.
When I did mine I forgot to tape the tensioner down. When I was putting it back together the chain didn't seem long enough to get the cam sprocket on, but it you turn the crank back and forth while pulling the chain upwards it will depress the tensioner. I had to do it this way because my cover was already installed.
(That's why I suggest putting the head on first.)
Well, yes.....but, you run a risk of buggering up the gasket with the head just resting and shifting around on it. Really, once you have the gasket and the head down on it, moving it around after the fact opens up undesirous possibilities.
I'm curious. Did you not use RTV at the recommended locations last time?
Oh, I see. The motor must still be in the vehicle, then.
Okay......well, try fishon's approach. It's obvioulsy quite doable that way.
Maybe look over this page before you continue, though:
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Sep 4, 2015 09:27 AM
