22RE Block Drain Plug...coolant
Old Apr 7, 2008 | 04:34 AM
BluYot's Avatar
Well, we were changing a couple rad hoses and decided to flush the whole system as well. The drain plug (block) was almost pooched/stripped so I'm wondering where I should get a new one. Dealership? Does anyone have any ideas? I could re-use this one but would be afraid that it's never coming off again...well at least without doing some damage. Thanks.
Old Apr 7, 2008 | 07:54 AM
thook's Avatar
You could, but I'd just try and fine another one from someone parting out or at a bone yard. Much cheaper....maybe even free.
If the threads aren't completely destroyed, you could try repairing the threads with a bolt chaser or die. Make sure the block threads aren't pooched, also. You'll back in the same boat trying to put a plug back in.
Old Apr 7, 2008 | 07:59 AM
BluYot's Avatar
Unfortunately there aren't any Toys in the yards around here....phoned the dealership though and they are getting one in from Cali. for $5. Not bad and shipping is paid.
Old Apr 7, 2008 | 08:04 AM
thook's Avatar
Oh! Problem solved, then. Cool.
Old Apr 7, 2008 | 01:38 PM
BluYot's Avatar
I'm just hoping the new one goes in smooth. Like you said though Thook, I can always chase it. Hope it works for $5!
Old Apr 7, 2008 | 03:45 PM
thook's Avatar
I'm not sure if loc-tite or anti-seize would be appropriate in this situation. Whichever is, either one will lubricate the threads and make reinstalling easier. Less chance of it sticking and crossthreading.
Old Apr 8, 2008 | 08:33 PM
longhungsilver's Avatar
I would use sum teflon sealant just to help seal it (it is part of the pressurized cooling system)
Old Apr 8, 2008 | 08:52 PM
CyMoN's Avatar
it is a good time to install a after market temp gauge that is where mine is installed.
Old Apr 11, 2008 | 08:34 AM
BluYot's Avatar
What's your temp gauge setup like? Any details? And as for teflon sealant...is it a tape or liquid/glue? I imagine it would have to be resistant to the high temps at the block though eh?
Old Apr 11, 2008 | 11:04 AM
CyMoN's Avatar
just a little tape is what I used I made a pillar for my gauges
Old Apr 12, 2008 | 11:50 AM
BluYot's Avatar
How do I go about wiring a coolant temp gauge....is it fairly straight forward? Do I tap into that drain on the block somehow?
Old Apr 12, 2008 | 04:07 PM
fast68's Avatar
pipe thread dope on a brush or in a tube works fine too, i use this when i install head bolts
always works great
so..
good luck
Old Jul 24, 2008 | 07:42 PM
854x4's Avatar
Sorry to bring back a old post but does anyone know what size,pitch,thread the drain plug is? I want to install a aftermarket temp gauge in my 86 but I need to know what adapter to buy.
RatOmeter
Oct 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
ryerye13
Jul 14, 2015 08:27 AM
Gamble_STi
Jul 7, 2015 07:54 PM
