Running rich?
Old Apr 1, 2008 | 04:53 PM
camdsgn's Avatar
Question Running rich?
I had to replace my catalytic converter a couple of weeks ago and since then my 3.0 has an unburned gas smell in the exhaust. So bad, I start it outside, fumes linger in garage too much.
Engine has a K&N Filter pak and I adjusted the AFM two notches leaner. It was running fine before the cat replacement; it's an aftermarket - couldn't see paying Toyota pricing.
All the stock sensors are in place as is the stock muffler.
Any suggestions? Thanks!
Old Apr 1, 2008 | 05:23 PM
norcalsvx's Avatar
maybe bad O2 sensor when did you last replace it
Old Apr 1, 2008 | 10:49 PM
prodigy2k7's Avatar
new 02 sensor, just for kicks, disconnect the battery to kill the computer. after 30 seconds reconnect it
Old Apr 1, 2008 | 11:00 PM
muddpigg's Avatar
I've got a RV cam in mine. The AFM and ECU don't seem to adjust to weather changes very well. It will run rich or lean as the wheather changes. Unburnt gas will kill a convertor. Really a PITA, I just turn the AFM wheel one click depening on the situation.
I'm sure its not the best solution.
Old Apr 2, 2008 | 07:57 AM
DCYota's Avatar
Have you used an ohm meter on that handy dandy throttle position sensor? That can affect fuel ratios as well if it's not in spec.
Old Apr 29, 2008 | 10:11 PM
Aywilkerson's Avatar
well I have the smae smell coming from my exhaust and it seems to run a few rpms higher at idle now too, I have not changed the o2 sensors and I always have a check engine light on. does this sound like a classic o2 sensor problem?
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
