90 runner engine codes
43= starter signal (STA) not sent to ECU even after ECU determines engine RPM's at 800 or more
52= with engine between 1600-5200 RPM, no input to ECU from knock sensor for 6 crankshaft revolutions
That help?
That help?
43 suggests an issue in the wiring between the ignition switch and the ECU, or possibly that the truck has been started by 'bump' starting
52 suggests an issue with the wiring between the knock sensor and ECU, or possibly a knock sensor failure
WI Girl
Jun 25, 2015 03:45 AM
jmc88runner
Jun 18, 2015 03:39 PM
