FRONT Power window relay location?
Old Sep 24, 2009 | 07:55 AM
A.Wilson013's Avatar
I have a wiring diagram, but it's really not helping me much.
Does anyone know where the Power Window Relay is for an 87 SR5 4runner? The FRONT windows. Not the back.
Thank you,
Alex
Old Jul 17, 2010 | 03:16 PM
toyaholic's Avatar
i am having the same issue. the fsm shows that it is under the dash near the the e brake switch but i see nothing? same truck, 87 4runner sr5.
Old Jul 17, 2010 | 08:09 PM
weaselman's Avatar
yes. its under the dash near the ebrake and stuff
Old Jul 17, 2010 | 08:48 PM
Tofer's Avatar
Sponsor
my 89 is located behind the ECU on the passenger side kick panel.. its called the Door Control relay.
Old May 14, 2018 | 11:59 AM
rickw51's Avatar
Power window relay on 93 4Runner
Thank you,
Alex
On my 93 I went nuts looking for it and finally located the relay in the rear compartment behind the left rear storage box. I was actually troubleshooting a left rear speaker problem when I stumbled upon the relay.
Old Sep 15, 2024 | 04:26 AM
Nedakj's Avatar
I have the 88 V6 runner and found the control unit on the passenger kick panel. We found the nasty solder joint and resoldered it. Unfortunately during testing it started smoking. We did a pretty neat solder joint so wondering if we have too much load going to the board which caused the original problem. i guess looking for new board might be my solution.
the board
sheebaracer
Jan 4, 2012 11:58 AM
SR5
Jun 23, 2011 07:10 AM
Romix
Mar 16, 2010 08:11 AM
mangroveboiga
Jun 23, 2009 11:12 AM
CBDenver
Nov 7, 2002 02:30 PM
