Front A.D.D diff electrical plug connection??
Old Sep 25, 2009 | 05:52 PM
Toyotoy's Avatar
I just bought a 93 4runner, 22RE, 5speed, it has the A.D.D front diff, but the wire for the actuator on the diff is just hanging there...i cant find anywhere to plug it into?? the two vacuum lines are attached and run up to the side inner fender wheel, but not a thing to plug this into...I did find a lose wire connected to the battery tray hanging down , but real short and different connection type and 3 ft away...In the end is this a 12v circuit i could just put a toggle switch too? help!!
thanks
Old Sep 26, 2009 | 09:44 AM
Toyotoy's Avatar
Front diff A.D.D plug?
thanks
Old Sep 26, 2009 | 11:37 AM
Jay351's Avatar
Hmm, so I take it 4wd does not work?
Old Sep 27, 2009 | 02:35 PM
bugs1961's Avatar
I don't know if you have solved the problem yet, but I'd take your question over to the 86-95.5 forum and ask again. I'm sure someone with ADD will answer your question. There are a bunch of really talented folks over there. I don't have ADD so I can't help you.
Old Sep 27, 2009 | 02:58 PM
eric-the-red's Avatar
That wire isn't for the front diff. The connector for the diff is already plugged in. And t's not for the actuator, that is totally vacuum operated. The wire just plugs into a switch that turns on the 4WD light when the diff is engaged. I would have a look above the diff for a matching plug for that wire.
It's been 4 years since I owned a 2nd gen so I'm not sure what else is around there.
Old Sep 27, 2009 | 03:13 PM
Toyotoy's Avatar
Thanks for that, that helps a bunch, still havent found any empty wire that is for that plug...i will keep looking, thanks
Old Sep 27, 2009 | 04:09 PM
toyota4x4907's Avatar
Look near the oil filter
jerusry
Oct 19, 2015 05:28 PM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
Daneums
Aug 20, 2015 05:36 AM
87turboPA
Jul 12, 2015 07:49 AM
