Idle problems in my 1991
Old Sep 20, 2009 | 01:48 PM
cupieking's Avatar
So, I just bought my 1991 4Runner and it has been a long awaited dream... I am having a problem with the idle though. When I turn the A/C off the trucks sounds like it is about to stall and much like it has some sort of Cam. When I turn the A/C on and the fan on 2 or 3 setting, it idles fine. Any help would be appreciated.
Old Sep 20, 2009 | 04:26 PM
Junkers88's Avatar
What does it idle at without the AC on? I ask because it sounds like it might be sitting at too low of an idle.
Old Sep 20, 2009 | 05:53 PM
cupieking's Avatar
I am not sure of the exact idle speed. It basically lopes and sputters without the AC on. As soon as I turn on the AC it smooths out and runs fine.
Old Sep 21, 2009 | 06:19 AM
Junkers88's Avatar
Does it have a tach in the dash gauges? If so then this will be easy. If not then we have something else we can try.
Old Sep 21, 2009 | 02:59 PM
cupieking's Avatar
I do not have a tach in the dash. I did notice another factor today though. It doesn't sputter with the AC off when the engine is cold and not warmed up. Could it be my computer that allows for more gas because of the temperature and then once its warmed it restricts the amount? Timing? Who knows......
Old Sep 21, 2009 | 10:32 PM
Swim's Avatar
I have almost this same problem. I just bought my 1990 today, I KNOW it needs a headgasket, but when I moved it to my shop today (first time driving it) it started out just fine... once it warmed up it started to idle @ 500rpms, then 1000, then 500, then 1000... once I stepped on the gas, the problem was gone. When I let off the brake without adding gas or in gear, it raised the rpms to 1000, 2000,1000,2000,1000.... again, once I stepped on the gas, it was gone.
Old Sep 22, 2009 | 05:09 AM
Junkers88's Avatar
Your Idle Air Control Valve is what adjusts the idle when the engine is cold/warm. Next time your around the truck do me a favor and increase the idle a little at a time until it stops sputtering. Then turn the AC on and see if there is a huge change. I really think it is idling too low.
Old Sep 22, 2009 | 05:12 AM
Junkers88's Avatar
That sounds like a bubble of air in the Idle Air Control Valve.
Old Sep 22, 2009 | 04:20 PM
cupieking's Avatar
Junkers, I will check out my truck when it quits raining here and as soon as Uncle Sam gives me some time off. I do really appreciate all your help. I will update you when I find the culprit.
Thanks
Tadd
Old Sep 22, 2009 | 06:36 PM
NYChopshop's Avatar
are you talking 3vze 3.0l v6, or 22re 4-banger? Lets see some pics. Sounds like the idle air controller to me too. Also, check on the health of your vacuum system and pcv valve, but I'm pretty sure I didn't need to mention that.
Old Sep 22, 2009 | 07:11 PM
vsuperman's Avatar
i have the same problem too.. I found that my idle screw moves when i give it gas. I dont know if this was the right fix but i put some tephon tape around the screw and re-set the idle to 900 rpms. seem to be working. i also advanced the timming just alittle bit.
22re 1995
Old Sep 22, 2009 | 07:13 PM
vsuperman's Avatar
where is this located pics help thanks
Old Sep 22, 2009 | 11:12 PM
Swim's Avatar
Which one of us are you referring to? I've got the 3vze located in Anchorage Alaska
Old Sep 23, 2009 | 05:09 AM
Junkers88's Avatar
The IACV is located under the throttle body. I'll try to find a picture here in a little while.
Old Sep 23, 2009 | 06:03 AM
TNRabbit's Avatar
Have you adjusted your hot idle yet? The IACV idles up the engine when the A/C compressor kicks on, so if it's dropping down too low when the A/C isn't on, you need to adjust your idle. The idle screw is FLAT HEAD & is RECESSED into the front (grill side) of the Throttle Body. You can see it when standing directly in front of the truck.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
