Glowing exhaust
Old Sep 23, 2009 | 05:56 PM
Romans117's Avatar
Glowing exhaust
New long block 22re. Bored .20 over, new head, turned cam, valves new or ground. Timing is set at 4 to lower idle to 900 rpm with jumper wire. Knock sensor is the only code. Great power. Runs smooth. No cat. Exhaust is flowing great. Injectors done by witchhunter two weeks ago. TPS has been adjusted. Egr good to go.
In other posts I read about the timing causing a red manifold, if the knock sensor is causing a check engine light it may effect the ECU's management of the timing advance. Is this accurate?
Old Sep 23, 2009 | 07:13 PM
Jay351's Avatar
you are probibly running lean...
Old Sep 23, 2009 | 07:18 PM
iamsuperbleeder's Avatar
personally, I'd install a new knock sensor, then go back and readjust your timing, cause I can almost garantee that bad sensor is throwing EVERYTHING off...
if the glowing exhaust persist after that, then you can start guessing at parts, lol. just fix what you know is broken first
Old Sep 23, 2009 | 09:30 PM
RMP8080's Avatar
Where and when is this happening, when I drive on the beach my exhaust glows. Of course at night when it's dark...........
Old Sep 24, 2009 | 04:16 AM
Romans117's Avatar
The motor has 35 miles on it. Night time.
Old Sep 24, 2009 | 11:28 AM
well I bet it glows during the day time too, you just can't notice it
Old Sep 24, 2009 | 11:47 AM
mokancraig's Avatar
I'll agree, either you're running lean or your timing is retarded.
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
