3.0 crank pulley problem help plz
1988 toyota pickup has 3.0 took the crank shaft pully with power steering keeps spinnng 2nd time there in no key way in the shaft only one way i see is that to take a larger key and grind it down to fit in the smaller key way in the timing belt gear but there has got to be an easy way other than welding it which is my fall back plz any input is most appriciated thank you
1 Post
From what you are saying I'm guessing someone didn't torque the crank pulley down and it wore off the the key way in the shaft? is this correct?
This happened to me several years ago. The previous owner of my 94 PU with the 3.0 beat the balancer/pulley on with a hammer and did not have it lined up properly. This created a tiny bit of slop between the keyway on the balancer and the key. Over time the pulley wore the key down until it was worn very evenly and you could just barely make out where the key was at on the crank. I had to look very closely and when I found it I was able to tap tap with a hammer and chisel to coax it out. I did not have to hit it very hard, just tap and it will come out. Inspect the keyway on both the crank and the pulley. I needed a new pulley and key and was back in business.
ZONAYODA
07-13-2015 07:17 PM
