94 4Runner Stalls
Old Feb 21, 2006 | 07:00 PM
exploito's Avatar
94 4Runner Stalls
when i go to start my truck it starts up fine and everything, but then i put into reverse, drive it stalls sometimes i can get it to run in reverse but when it does it acts like it wants to stall, runs baddly virbrates and stuff when i press the gas to backup it stalls, but when in park it runs fine and dandy,if i rev the engine as i put it into reverse or drive i can get it to drive away, but when i come to a stop it acts up vibrates and stalls..
it never done this b4 it just started doing it
any clue on how to fix this ? im moving down south in a fewq days need this truck running..
Old Feb 21, 2006 | 07:10 PM
scenarioL113's Avatar
First off check the tranny fluid just in case.
Could possibly be some kind of problem with the reverse clutches or bands. I am not really too familiar with the Toyota auto-tranny. If it is a problem like that it will probably need a mechanic to check it out. If it has a lot of miles (which I am sure it does) they probably will want to rebuild it. I dont know if the bands are adjustable, they may be. Lets see if someone who knows a little more writes a post.
Old Feb 22, 2006 | 06:20 AM
regularguy412's Avatar
I'd almost bet it's not the transmission. Make sure the engine has good fuel pressure -- check or replace the fuel filter and/ or the fuel pump.
We're making the assumption the vehicle has an auto tranny. The runner probably has an A340H or A340F auto tranny. There are no bands in the late model transmissions. All the shifting is performed by hydraulics and electric solenoids. There could be a solenoid going out or some of the hydraulic seals are wearing out. That is,, provided the engine is operating properly.
Mike in AR
Old Feb 22, 2006 | 06:30 AM
tc's Avatar
tc
Originally Posted by exploito
i put into reverse... when in park ... put it into reverse or drive
Not many people describe putting a manual tranny in park or drive. I think it's safe to assume it's an auto. LOL
Which engine?
Done a tuneup (cap, rotor, plugs, wires) lately?
Any idea when the tranny fluid was flushed/changed last?
Old Feb 22, 2006 | 06:32 AM
Touche' TC.
LOL
Mike
Old Feb 22, 2006 | 06:54 AM
Worley's Avatar
Does Toyota use a lock up converter? If it does it could be permanently locked up. If that is the case you can unplug the solenoid that allows this to happen. But I am not familiar with toyota automatics. But I have had similar cases with different vehicles in the past. Unplug the wire that controls the lockup soleniod and drive it. The only thing it effects is the gas mileage. You will get maybe 2-3 mpg less.
Old Feb 22, 2006 | 07:12 AM
snap-on's Avatar
and HEAT ..with out the ablity to lock up it will generate LOTS of it!
Old Feb 22, 2006 | 07:34 AM
Worley's Avatar
I don't think so. If it doesn't lock up it won't generate any more heat. It isn't locked up all the time anyway. There are certian conditions that need to be met before it will engage the lock up. So not having it hooked up will not hurt the transmission and it will not generate any more heat.
Flying91
45
Apr 11, 2024 04:39 PM
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Jnkml
Jul 6, 2015 01:20 PM
