When doing 3.0 valve cover gaskets...
Old Feb 23, 2006 | 01:59 PM
rpeAMP's Avatar
How close am I when tearing into the top of the engine to accessing the headgasket on this engine? I have certain symptoms that lead me to believe I have a leaking headgasket and thought that it would be good to do all the work at the same time.
I've searched around here but can't seem to find any sort of write-up related to the headgasket.
BTW- Mine's already been done under warranty a few years ago, so I'd have to pay for it to be done again or do it myself.
Old Feb 23, 2006 | 02:21 PM
suprathepeg's Avatar
Pulling the heads is a lot more involved then just the valve cover gaskets. You have to tear into the front of the engine as well as the exhaust manifolds and such. You can look up pulling the heads in the FSM here:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Feb 27, 2006 | 07:49 PM
rpeAMP's Avatar
That's what I needed to know! Thanks.
Old Feb 27, 2006 | 08:11 PM
ChickenLover's Avatar
Here is a photo of my HG repair. It should give you some idea of just how involved this job is.
Old Feb 27, 2006 | 08:47 PM
AgRunner06's Avatar
I would do a compression check first to verify a leaking HG then go from there.
Old Feb 27, 2006 | 09:05 PM
rpeAMP's Avatar
How would the compression test indicate leaking, would it just have low compression on one or more cylinders or are there other indicators?
Old Feb 28, 2006 | 02:00 PM
AgRunner06's Avatar
Yes it will have low compression in one or more of the cylinders. There are also other factors like a whitish substance on the inside of the oil cap, disappearing coolant, and a sweet smelling exhaust. It can cause the vehicle to run bad and hot but not necessarily.
Try searching. There are LOTS of threads on the 3.0 HG leak.
Good Luck
Old Feb 28, 2006 | 04:42 PM
rpeAMP's Avatar
Several of those headgasket posts are mine.
The only headgasket symptom I'm having is an unexplained loss of coolant from the overflow tank, and it seems that my system builds pressure rather quickly. I had a shop do a block test, no exhaust gases in coolant or anything like that. They also couldn't find any external (hose) leaks. No mixture of fluids that I can tell, so at this point I'm looking for a coolant leak that allows the coolant to vaporize before hitting the ground, because I have no visible spots on the ground.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
keithporter83
Jul 18, 2015 12:37 PM
