Fuel filter will not come off!!!
Old Mar 6, 2006 | 10:20 PM
MorphiasX's Avatar
I am changing my fuel filter, and I cannot get the line nut to come off. Its on the side that goes to the fuel tank, its a 19mm on the filter, and a 14mm line nut. I used a 19mm wrench to hold the filter, then used a line wrench (goes about 3/4 around the nut) to turn the nut. It will NOT turn no matter what I try. It ended up starting to round the nut with the line wrench! So I used vice grips, and a cheater bar, and it still will not come off! And I also sprayed it with WD40 in the beginning. What can I do?! Anybody else have this happen to them?
Old Mar 6, 2006 | 10:24 PM
photoleif's Avatar
steve, that same thing happened to mine once (mechanic's report) -- they had to cut the line, clean, re-crimp and re-shape it, etc. the nut just wouldn't budge.
Old Mar 6, 2006 | 10:36 PM
Bob_98SR5's Avatar
WD40 is NOT a penetrant! go buy some PB blaster and soak it overnight or two nights.
Old Mar 7, 2006 | 05:10 AM
VA_Yotaman's Avatar
I 2nd the PB Blaster. I haven't seen anything that a good soaking of Blaster over a couple of days wont take off.
Old Mar 7, 2006 | 05:17 AM
rentedmule's Avatar
I haven't been able to get mine changed for the same reason. Mechanic tells me they'll have to change both the in/out lines if I want to put the new filter on.
Old Mar 7, 2006 | 05:48 AM
bryanr's Avatar
I ended up replacing both fuel lines when I did mine. The prior owner must have never, ever changed it.
Old Mar 7, 2006 | 06:48 AM
F0RSAKEN's Avatar
Changed mine at 148k, and it was a BITCH to get off. I let it soak with WD40 (yes PB blaster is better, but it was all I had) for about 20 minutes, and put my less than huge arms to work. Probably took me an hour total to change the damn thing.
Old Mar 7, 2006 | 07:46 AM
mt_goat's Avatar
One thing that helped me get mine off after the nut started to round off was to file the sides of the nut down until the next smaller size line wrench fit nice a snug. I was just about ready to cut mine off when my neighbor got it loose for me.
Old Mar 7, 2006 | 08:41 AM
Platypus1's Avatar
dude go to pep boys and buy a flare wrench set for $10. I couldnt get my filter nuts to budge at all until I used them. Also, I tried the 'ol tobasco sauce trick as well, the combination worked well.
Old Mar 7, 2006 | 10:43 AM
VA_Yotaman's Avatar
Old Mar 7, 2006 | 10:47 AM
Bob_98SR5's Avatar
yes, tabasco sauce works. i usualy dont give that advice b/c most people think im nuts when i suggest it
Old Mar 7, 2006 | 10:51 AM
surfmobile's Avatar
you cant be serious about the tobasco sauce. if u are im gonna try it cause im having the same problem.
Old Mar 7, 2006 | 11:35 AM
photoleif's Avatar
ok guys, what's up with the tabasco sauce? vinegar as a mild acid slowly chewing up the gluck?
Old Mar 7, 2006 | 12:48 PM
kpaxfaq's Avatar
PB blaster will take anything off
Old Mar 7, 2006 | 02:52 PM
leebee's Avatar
yeah, let us in on the secret! im planning on changing my fuel filter in the spring and i have a bottle just waiting.
lee
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
