Timing a 3.0
Old Feb 27, 2006 | 12:45 PM
jjenks0's Avatar
Timing a 3.0
I hooked up my timing light and inserted my paperl clip into the little slots like it shows in the picture. My timing was at 10 degrees TDC. I took the paper clip out and it was still 10 degrees TDC. Could it be my paper clip was not doing its job?
Jack
Old Feb 27, 2006 | 12:54 PM
runethechamp's Avatar
1. Search
2. Adjust your TPS
Old Feb 27, 2006 | 02:42 PM
ChickenLover's Avatar
Possible. Try using something that fits tighter. I stuff a piece of wire in there (nice tight fit). FYI, my timing usually moves about 2* when the jumper is removed.
Old Feb 27, 2006 | 02:46 PM
Good way to see if you have a connection is to see if the check engine light is blinking with the connector in.
Old Feb 27, 2006 | 03:01 PM
jjenks0's Avatar
thanks for the information. I did not check for the check engine light blinking. Theres grease in the fittings so I could not tell if the clip was in the correct place.
Old Feb 28, 2006 | 08:51 AM
MightyToy's Avatar
can you explain how to adjust the TPS? Thanks
Old Feb 28, 2006 | 09:19 AM
I could do a write-up of it, but 4crawler has a good one.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
If you have a V6, you need to apply vacuum to the throttle opener as well, described in the FSM.
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Roger Borba II
Jul 9, 2015 05:05 PM
