t-case rear output bearing
Old Feb 24, 2006 | 07:29 PM
tntoyota22's Avatar
ok im about to try to change the rear output shaft bearing in my 87 truck. Ive never done this before and need advice frome someone that has. Im changing the bearing because i can move the drive shaft up and down about half and inch in any direction. the trnsfer case hase 7 bolt on the rear retainer plate if this helps.
Old Mar 3, 2006 | 05:58 AM
tntoyota22's Avatar
Am i here all alone.
Old Mar 3, 2006 | 06:47 AM
seaflea's Avatar
Have you pulled this case out of the rig yet? You will need a press to take off and replace it. You may as well plan on rebuilding the whole case while you are at it. If the bearing is as bad as you say, there will be a lot of metal floating around in there and has started to tear up other parts also.
Good luck.
Old Mar 3, 2006 | 06:55 AM
Cebby's Avatar
Good luck.
I'd agree with this assessment. Have torn two down a little while ago, there's a lot of things to inspect in there. Fortunately for me, mine were in great shape inside.
88sasturbotoy
Jan 30, 2026 01:57 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
coffey50
Jul 28, 2015 10:55 AM
89hilux1
Jul 19, 2015 01:32 AM
