V6 4x4 manual shifting problem
Old Feb 22, 2006 | 03:20 AM
pangura's Avatar
I recently replaced my clutch and have the following problem. After driving around for a little while I have problems shifting vehicle in gear after making a stop. It completely refuse to go in gear. When I switch off vehicle, it slide right into gear. Also, when shifter acts up, vehicle reacts like an automatic and I have to set on my brake with the clucth depress, otherwise vehicle will move forward. When this happens, it is also difficult to gear in neutral. I have replaced shift lever seat without any success.
Old Feb 22, 2006 | 07:00 AM
celica's Avatar
sounds like the clutch isn't fully disengageing. Take it bake to who did the clutch & tell them to look at it since it isn't releasing.
Old Feb 22, 2006 | 07:04 AM
snap-on's Avatar
have you checked your fluid level or bled the system sence you did your clutch work?
also did you reset the clutch peddal height? there is a procedure for it i think.
Old Feb 22, 2006 | 10:31 AM
Worley's Avatar
sounds like your hydraulics are not working correctly for your clutch. Check your slave cylinder and master cylinder for proper operation.
Old Feb 23, 2006 | 08:54 AM
Bobakazi's Avatar
Did you pay to have it done somewhere? They have to guarantee their work. Bring it back.
If not: when you can get it into gear, does it release really close to the floor?
Old Feb 23, 2006 | 09:04 AM
shiftless89's Avatar
mine had similar problems, the pressure plate was not fully torqued down flat on the flywheel. It had reached the correct torque but there was so much tension on the pressure plate it was not flush against the flywheel..
Old Feb 23, 2006 | 08:41 PM
pangura's Avatar
I was thinking of changing the transmission fluid with synthetic oil GL-5 and see how it works. Shiftless, what did you do to solve your problem?
Old Mar 9, 2006 | 12:23 PM
osr436's Avatar
pangura
I'm having the same problem. I had my clutch replaced back in November and ever since it has shifted poorly. It's hard to get it into gear; if I"m slowing down and go from 3rd to 2nd I have to almost double clutch. (or pump the clutch a few times)
Now I had a Non-Toyota Mechanic replace it and I think that might have been my problem. Since then it has been to toyota for more bleeding, which has improved the shifting.
When I was at the toyota dealership, they asked if my mechanic used Toyota Geniune parts. (he didn't) They told me they have seen this before when Toyota parts are not used. (Of course I didn't believe them, but I did some research on this site and others and I read where a few others had the same problem with after market parts. When they replaced the after Market with Toyota Genuine Parts... Problem was fixed.)
(As a note; The problems others were having was with the after market Clutch MC and Slave Cynlinder)
The dealership also told me bleeding that system is a pain. So maybe you need to bleed it more.
For me, I'm debating sending it to the dealership for them to look at it. I'll keep you posted
Osr436
Old Mar 9, 2006 | 12:24 PM
osr436's Avatar
pangura
Oh by the way, I also changed my Trans fluid to Redline and it didn't help....
Osr436
mskalmus
May 28, 2017 07:51 AM
Yota.Jay
Jul 23, 2015 08:08 PM
ItsJustD
Jul 7, 2015 07:49 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
