Removing oil dip stick tube on 22RE
Old Mar 5, 2006 | 06:40 PM
FMH60's Avatar
Does anybody have any suggestions for removing the oil dip stick tube on a 22RE? I have the engine completely disassembled. Thanks in advance.
Old Mar 5, 2006 | 07:24 PM
netgodsrdn2's Avatar
Mine was just siliconed in. So after I pulled the bolt out at the top of the tube I just pulled it out.
Ron
Old Mar 5, 2006 | 07:38 PM
FMH60's Avatar
Oil dip stick tube
I thought it should come out that way, but mine is stuck fast. I'll just keep working it around and see if it will come loose. Thanks for the input.
Mark
Old Mar 5, 2006 | 09:32 PM
kyle_22r's Avatar
why are you trying to remove the tube exactly?
Old Mar 5, 2006 | 11:57 PM
I'm not sure why Mark is pulling his but I had to move mine to my new long block...
Ron
Old Mar 6, 2006 | 04:39 AM
FMH60's Avatar
Same here. I need to move it over to a new long block.
Mark
Old Mar 6, 2006 | 07:56 AM
yota7's Avatar
i had the same problem with mine. all i did was take a pair of pliers and carefully move the tube around, then when it gets looser it should just pop right out. it took me about 10 minutes to get it loosened up. just work at it
bryan
Old Mar 6, 2006 | 08:18 PM
InternetRoadkill's Avatar
You can remove it if you *carefully* drive it out with a large punch from the bottom side of the block. (The pan needs to be off to do this.) Place the punch on the lip of the tube where it inserts into the block and tap it out. Do this gently or you'll curl the lip closed. Use the largest punch that will fit the hole in the block.
Old Mar 7, 2006 | 08:58 PM
kyle_22r's Avatar
best application for that would be a brass drift, keeps from mangling the steel up.
Jun 1, 2021 01:51 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
