tire questions???
Old Feb 23, 2006 | 03:16 PM
V_Runner's Avatar
Banned for stupidity
tire questions???
ok my 89 4runner(stock) needs new tires and SOON... i have the P235/75/R15's on there now and i want to put the biggest size tire on that i can... so my question is what is the biggest size i can get??? what brand should i get??? any info is greatfully welcomed...thnxs
PS. i want tires meant for on and off raod... thnxs
Old Feb 23, 2006 | 03:21 PM
VA_Yotaman's Avatar
Biggest I've ever seen stock was 32x11.50. That is with the torsion bars cranked up. You may be able to do a narrow 33", but I've never seen it. As far as off road aggression, I've never had a better tire than a Swamper TSL. I'm talking mud here, not rocks and sand.
Old Feb 23, 2006 | 03:34 PM
breknraj's Avatar
I've always run BFG All Terrain T/As in 31x10.5.
I've found them to be a good all around tire, and they don't squat too much when I'm loading green fire wood. I've done some local and Moab wheeling with them (nothing real tough), and they perform pretty well on the abundance of white stuff around here, too.
Old Feb 23, 2006 | 04:02 PM
lofreqjeff's Avatar
I just got some Goodyear Wrangler MT/R's - 31X10.5x15 for my 89 4Runner and I LOVE them!
I wouldn't go any bigger without some kind of lift. When I'm off roading, they almost rub. If I would have gotten the 32X10.5's I definately would have some rubbing when the axles are articulated.
Old Feb 23, 2006 | 04:36 PM
regularguy412's Avatar
I believe that tc on here runs 33 10.50 Dunlop Rovers without a lift. Not sure if he put a small lift on or if he also had to flatten the fender seam.
The biggest tire rated for a stock 4runner is 31 10.50. That assumes stock wheels with the stock wheel backspacing. I suppose you could play around with wheel width, backspacing, and tire brands / sizes to fit slightly larger -- if you wanted to take the time.
I'm running 31 x 10.50 Michelin LTX M/S tires on stock alloy rims. Tires are GREAT in snow,, average in mud and they wear forever.
Mike in AR
Old Feb 23, 2006 | 04:46 PM
mehret's Avatar
I second the Goodyear Wrangler MT/Rs 31x10.5s. For me personally, they're kind of pricey, but I know they're well worth the money.
Old Feb 23, 2006 | 05:33 PM
87rustbucket's Avatar
vin, i told u that u can go up to 32's with stock hight. Just cant trust me huh?
J/K i know you just want bigger and better tires than me lol!!!
Old Feb 23, 2006 | 05:52 PM
V_Runner's Avatar
i was also thinking of going with an offset kit and a 3inch lift this summer..if all goes acording to plan...anyone know of any good wheels with built in offset kits???
Old Feb 24, 2006 | 12:29 AM
tc's Avatar
tc
Yep - 33x10.50 on stock rims with no lift (no torsion bar crank, no fender manipulation, nothing except fix the saggy butt) and no rubbing on my 2nd gen. Wouldn't think you would have a problem on the first gen (4crawler runs this size too, but I'm sure he has lift)
I think they look great. Some pix here www.4wheelingoh.shuuterfly.com/action. The gold Taco has 33x10.50 BFG A/T and the black Taco has 34x10.50 SuperSwampers.
ONLY problem with this size is lack of choices. BFG A/T and M/T, Dunlop Radial Rover RVXT, and Super Swamper are about it.
Old Feb 24, 2006 | 12:15 PM
V_Runner's Avatar
thnxz tc
Old Feb 24, 2006 | 06:33 PM
tc's Avatar
tc
Although you asked what the bigegst you could get was - I think Interco makes tires up to 49". Will need a lot fo lift for those! LMAO
Biggest I've seen on a 4Runner are the 40's on 4Mogger here.
Old Feb 25, 2006 | 05:30 AM
V_Runner's Avatar
WOW... thats fffffin huge!!!!
Old Feb 25, 2006 | 08:34 PM
JonathanG32's Avatar
i have the 34 inch by 10.50 ltb tires and when i take them off road in colorado they get so much grip. and when i air down i get even more grip good tire well worth the money
Old Feb 27, 2006 | 02:13 AM
V_Runner's Avatar
how about offset bolt-on's are they any good???
Old Feb 27, 2006 | 08:40 PM
1985 4Runner's Avatar
I had 31x12.50x15 on my stock 1989 before I lifted it. After a 4" susp. lift & 3" body lift, I was able to fit a set a TSL SSR's in 33x14.50x15 very nicely. Backspacing was 4 if I remember right. The stock V-6/gears turned them without too much problem. Heres a pic of my old 1989 with the lift/tires.
1985 4Runner 355 chevy, 11" lift, 39.5x18x15 Boggers.
Old Feb 27, 2006 | 08:47 PM
If you want to see what it would look like on 40's here is one of my 1985 4runner on 39.5x18x15 Boggers. I have a thread with a few more in the 84-85 4runner section.
Old Feb 28, 2006 | 02:32 AM
V_Runner's Avatar
very nice...but i stilll want to know if bolt on wheel spacers or offset kits which ever you can them are good and how much???
Old Mar 2, 2006 | 08:38 AM
When I ordered my tires for my 89, I got a great deal buying a package rims/tires from 4wheelparts.com They were very good to deal with. Knew exactly which rim/tire would fit my truck with my lift. So it took all of the guesswork out for me. As far as the spacers or offset kits, I don't know. But the Super Swamper SSR's in 33x14.5x15 worked great offroad & great onroad. They were so wide that there was very little wear after 20k miles. Well worth the money in my opinion. In fact, I will prob get a set for on road use & save my boggers for the trail.
Old Mar 12, 2006 | 06:05 AM
V_Runner's Avatar
what's the bigest/widest i can fit on with aal's, t-bars crancked....also with stock 15s and stock gears????i was thinking 32x11.50...will they fit???
Old Mar 12, 2006 | 07:24 AM
91_4x4runner's Avatar
My sources say yes
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
