Tech guy help me! Broken cam tooth, is it ok?!
Old Mar 1, 2006 | 08:11 PM
chuck3436's Avatar
Hey guys, a newbie here, but im on my last financial legs for my beloved truck. Hope you tech guys can help, because i havent been geting any responces from others regarding this!
So my distributor seized, with all the goodness that brings.
Has a half chipped cam/drive tooth and a chip off another one.
Do you think putting in a new distributor will be ok with the chipped tooth? Will it misfire or cause problems? I dont really see how as the distributor is free floating and wont cause much to turn. Im THINKNIG it should be ok, as i dont see how it could really cause a bad skip or anything. Im sure the other teeth or the simple momentum will be enough to keep the thing turning properly. But no one i know has seen this and can say for sure.
now getting a new gear shimmed and installed is a terrible price of nearly 1000$ all in all. I dont have that money, nor do we have the know how on how to PROPERLY do it......this is a week after my last $$$$ went to fixing a leaky water pump which i included the timing belt..........
Any thoughts guys? Pleeeeeeeeeeeease tell me it should be ok.....
90 v6 auto.
Old Mar 3, 2006 | 02:17 PM
peterng's Avatar
replace it, get one from a junk yard or something
Good luck !
Pete
Old Mar 3, 2006 | 03:50 PM
spyne's Avatar
It's just another, bigger, problem waiting to happen if you don't fix it properly now. Do what peterng said and find a cheap replacement somewhere. It will save you a ton of money in the long term.
bigjstang
Jun 2, 2025 03:56 PM
thefishguy77
Jul 30, 2015 10:59 AM
voiddweller
Jul 15, 2015 03:56 PM
88yodabasket
Jul 13, 2015 01:32 PM
timmJ
Jul 7, 2015 02:01 PM
