Engine Degreaser
Old Feb 28, 2006 | 04:43 PM
dmatter's Avatar
Engine Degreaser
I am Currently Trying to Locate Oil Leaks on my New 88 V6 4Runner. I was Wondering What would be the Best way to Thoroughly Clean/Degrease the Engine so I can Locate Leaks. I was Thinking about using Oven Cleaner on the Axle, Skid Plate Etc, Places where there are no Wiring Harness or Plastic and regular Degreaser on Everything Else Followed up with a good hard Powerwashing. Is it Best to Leave the Engine Running While Cleaning? What do you guys Think about oven Cleaner? It is a VISCIOUS Cleaner. But, I am Sure it is'nt Good For Some Metals/Plastic.
Thanks in Advance
Dax
Old Feb 28, 2006 | 04:46 PM
Elton's Avatar
i used foamy engine bright worked really good or you could get it steamed cleaned
subliminaltrips's Avatar
i wouldnt use it near aluminum, like the head and timing cover or anywhere for that matter
Old Mar 2, 2006 | 12:04 PM
fnrunner's Avatar
just pick up the oil dye from Napa (think it was ~$3-5) for a 1 oz. bottle. Then pick up the dye flash lite & glasses @ AutoZone (basically a blue led mag lite & yellow tint safety glasses. I used a new bottle of oil for the dye & only poured 1/2 the bottle in, so I could use the rest for a later time.
Once you've fixed the problem, use simple green & a power washer to degrease - but be careful when spraying - stay away from electrical parts. Jsut use some common sense here...
I used the dye to find a cam seal leak on my 3.0L last year. Made my life a whole lot easier finding the leak.
Good luck!
Old Mar 2, 2006 | 03:07 PM
dmatter's Avatar
Thanks Alot Guys, I really appreciate your Help. I ended up Going With Oven Cleaner for the Front Axle/Skid Plate Etc. I Did'nt use it on The Upper End at All. Gunk Would Not go near the Mess I had under the Truck. The oven Cleaner Turned the Oil/Grease into a Gel and it All Came Right Off. I hope the Front Diff Was'nt Painted because it is now Silver Now to Find this Leak. I Think it might be Coming from the Power Steering Pump??? I hope So!!!!
Old Mar 2, 2006 | 04:20 PM
mtrdrms's Avatar
I like to use S-100 or Purple Power. I use it on my dirt bikes too and it works awesome for lifting the chain grime.
icentropy
Sep 16, 2020 02:47 PM
chukarhunt
Dec 8, 2019 11:39 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
