95 4runner (help with hoses) 3vz-e
Old Apr 6, 2013 | 07:26 AM
thectspot's Avatar
I need some help after me and my mechanic friend change the valve covers. I think we have everything else in place from the FSMs I have found on here but I cannot figure out where the empty hose (pictured below) is suppose to go. On an old picture I seen where we had it going somewhere but I can't find the hose and don't know where. Check Engine light is on and and I think this is the reason
Old Apr 6, 2013 | 09:17 AM
bpealer's Avatar
Mine runs down to a hard line then connects to one of the ports on the bvsv.
Old Apr 6, 2013 | 09:29 AM
rworegon's Avatar
Post #7 here shows the hose attached to the open port on a '94 and the photo in post 13 in the same thread shows it dropping down a bpealer explains.
Maybe it will jog the memory.
Old Apr 6, 2013 | 12:27 PM
thectspot's Avatar
Thanks, ended up finding it hiding. Now gotta figure out how to get the code for the check engine light.
Old Apr 6, 2013 | 02:47 PM
rworegon's Avatar
Pull the negative battery cable to clear the code and see if it reappears.
Edit: Or, the EFI fuse as scope103 reminds below.
Old Apr 6, 2013 | 05:35 PM
Co_94_PU's Avatar
Howto and codes are here.
Old Apr 6, 2013 | 06:28 PM
Sperry's Avatar
Here's a picture of my 95 3vze automatic.....
Old Apr 7, 2013 | 07:20 AM
scope103's Avatar
Your "hiding" vacuum line goes to the Thermal Vacuum Valve (TVV) and then onto the Evap Canister. Leaving it open will produce a very small vacuum leak, which might be the cause of your code, but probably not. DO pull the EFI fuse to clear codes, first. (pulling the negative battery cable is not only more difficult, but you'll lose all your radio stations, ...)
Old Apr 7, 2013 | 07:32 AM
rworegon's Avatar
Originally Posted by scope103
...but you'll lose all your radio stations, ...)
....in po-dunk USA, we only have 4 or so to worry about...no biggie.
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
