Broke the ECT sensor off. HELP MEEEE!!!!!
Old Apr 19, 2013 | 11:39 AM
GROUNDHAWG's Avatar
I installed a new engine coolant temp (ECT) sensor in my 89 yoter or tried, but upon installation i tightened it too tight and broke it off in the blockDoes ANYBODY know how i can get it out...
Old Apr 19, 2013 | 11:46 AM
wyoming9's Avatar
Red face
Calm down chill out!! Just what engine??
just how bad did it break off???
Are you talking it broke off flush or below the block??
Is there anything left to grab hold of a turn it out??
Were all pretty much just guessing here!!!
Pretty much worse case is drill it out!!:jessica::jessica::jessica:
Old Apr 19, 2013 | 12:11 PM
GROUNDHAWG's Avatar
its a v6 and it broke off flush as a toilet,
Old Apr 19, 2013 | 12:28 PM
GROUNDHAWG's Avatar
thought about trying a eeze out but i have never used one before.
Old Apr 19, 2013 | 01:49 PM
derockus's Avatar
ez outs are easy. drill a pilot hole in the borken bolt and then put the eeze out in the drill. throw the drill in reverse (leftyloosey mode) then slowly push the easyout in the pilot hole until it bites and it should lock on the broken bolt and start backing it out. heat may help, not sure.
Old Apr 19, 2013 | 03:02 PM
rbuchmann's Avatar
Drilling and using an easy out is your only hope. Make sure you center punch the broken part because you want to be as much in the middle when drilling. Then using an easy-out, slowly apply pressure until you get movement. I had to do this on a 10 mm bolt on my water outlet when I did my timing belt. Mu8ch smaller hole and got it on the first try. Start with a small drill bit first and then work your way up to the size of your easy-out.
Old Apr 19, 2013 | 06:23 PM
GROUNDHAWG's Avatar
Thanks guys for the info, will try this tomorrow and let yall know how it works!!
Old Apr 20, 2013 | 05:53 PM
GROUNDHAWG's Avatar
welp borrowed an eeze out and got it right out of there but one more question, looking from the drivers side, the sensor directly to the right of the ECT sensor is another sensor. can someone tell what that sensor is?
Old Apr 20, 2013 | 07:46 PM
rbuchmann's Avatar
I forgot or you didn't mention the engine, but assuming V-6, 3.0. This topic should answer the questions.
https://www.yotatech.com/forums/f116...s-3vze-224860/
Blamalam
Mar 12, 2022 07:34 AM
oldirtydirt
Feb 23, 2020 09:30 AM
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
lfcarrion3
Jul 18, 2015 04:05 PM
