Stiff shifting
Old Apr 20, 2013 | 04:24 PM
4runner20's Avatar
Stiff shifting
Im having trouble getting into just about every gear. When i put the clutch pedal to the floor in first, it is engaging just a little and the car will move very slowly. Is my clutch going out?
Old Apr 20, 2013 | 06:10 PM
Duckie's Avatar
Check you clutch master cylinder. Make sure it has fluid. Possibly replace if failing.
Old Apr 20, 2013 | 07:32 PM
rbuchmann's Avatar
There are a few things to check. Master clutch cylinder, the slave cylinder, or its the infamous clutch bracket fatigue.
Check this link for fatigue issues with the clutch bracket.
https://www.yotatech.com/forums/f116...fatigue-32667/
Old Apr 20, 2013 | 07:43 PM
saltandgranite's Avatar
I live in fear of the clutch bracket failure... Everytime I hear any type of spring squeak or anything I jump out of the truck and get under there with a flashlight. So far so good (knock on wood). Yikes.
Old Apr 20, 2013 | 07:50 PM
rbuchmann's Avatar
I bought a new bracket, installed it, and I still worry about when its going to fail. I think its just psychosomatic. LOL
Old Apr 21, 2013 | 12:31 PM
4runner20's Avatar
Okay well i check both master and slave cylinders for leaks-nothing, had someone engage clutch while i looked and slave-it moves in and out of bell housing, and the clutch bracket is intact and functional. Whats going on? Could the rod just need to be adjusted?
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
ktm192k
Oct 1, 2015 08:47 AM
creecher10
Sep 30, 2015 03:27 PM
