Coolant and Oil leak!
Old Apr 19, 2013 | 12:50 PM
Up_on_One's Avatar
I just recently picked up a 95 4runner and everything was going cool except for a small oil leak. i checked it out and had my mechanic buddy look at it and told me that it was coming from the back of the valve cover. he said I could just try to tighten it up and if it doesn't work he can help me replace the gasket. so I bring it back home and park it in the driveway only to come back later and there was a little puddle of both oil and coolant under the truck. I looked at the back valve cover where the oil was leaking from and did not see any signs of coolant there so I have no idea. it was all over the under of the car dripping but I can't see where its coming from... what could be causing this?
Old Apr 19, 2013 | 01:50 PM
GrandPrix's Avatar
Sounds like you might need to light the torch.
Old Apr 19, 2013 | 02:13 PM
dimitri's Avatar
At least on the 3VZ engine , there is an upside down U shaped coolant hose hiding in the back, best viewing angle is from the passenger side with a flash light.
Old Apr 19, 2013 | 02:43 PM
Up_on_One's Avatar
It doesn't look like the two have been mixed. looks as if separate leaks because the coolant and oil are both clean
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
jakebarrett
Jul 10, 2015 07:15 PM
