1st gen 4runner reman3.0L won't start
Old Apr 10, 2013 | 12:26 PM
wwrafter's Avatar
Just dropped a rebuilt 3vze into my 89. I had to pull the plenum a couple times to chase down a coolant leak. But the engine started up and ran smooth prior to that. This last time it started up and ran fine til it warmed up then began hesitating before it quit. After the engine cooled it started back up and ran for a short time before it quit again and then would start and sputter only. Now will not start at all. Any ideas?
Old Apr 10, 2013 | 01:30 PM
brianh699's Avatar
Any trouble codes?
Old Apr 10, 2013 | 01:33 PM
wwrafter's Avatar
Originally Posted by brianh699
Any trouble codes?
Don't have anything to check for codes. Working with limited supply of tools. Only what was needed to drop the engine in.
Old Apr 10, 2013 | 01:55 PM
Co_94_PU's Avatar
Read this.
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
And have one of these handy
Old Apr 10, 2013 | 02:30 PM
wwrafter's Avatar
I'll check and let you know.
Old Apr 10, 2013 | 02:39 PM
scope103's Avatar
Do the easy stuff first; trouble codes, timing, and I'd probably check compression just because it is so easy to do.
But if the only thing to change before/after was removing the plenum, the most likely problem is an error in reconnecting the vacuum lines.
Old Apr 10, 2013 | 04:43 PM
wwrafter's Avatar
Working on getting the trouble codes and will post the results soon. Not likely the timing ad the engine was running good after the plenum was reinstalled. I'm leaning towards a fuel delivery problem. I was very meticulous with labeling the vacuum lines prior to removal but they are getting old.
Old Apr 10, 2013 | 05:18 PM
TNRabbit's Avatar
Check for any cracks in the intake hose, also.
Old Apr 10, 2013 | 06:35 PM
wwrafter's Avatar
Ok. Checked for codes using the system in the above link but got no response.
Old Apr 10, 2013 | 10:04 PM
wwrafter's Avatar
Thanks tnrabit intake hose/ tubing in good condition. Any other ideas?
Old Apr 10, 2013 | 11:24 PM
Azcodito's Avatar
pull the plenum off again and check the fuel injector wiring harness. I know when I pulled my valve covers off I had to remove the passenger side plugs and lost the little plastic clip on one of them. Zip tied it down and solved the problem. Maybe one is not fully engaged and that is causing/caused your sputtering.
Old Apr 11, 2013 | 02:09 AM
brianh699's Avatar
In the diagnostic connector where you jumped terminals te1 and e1 to check codes, there are two terminals marked fp and B+ if you jump these it will apply battery voltage to the fuel pump. See if it runs then.
Old Apr 11, 2013 | 06:41 AM
TNRabbit's Avatar
When you say "no response", you mean you had steady flashing of the CEL?
Old Apr 11, 2013 | 11:38 AM
wwrafter's Avatar
The terminals are marked "T" and "E1" does this make a difference? I made multiple attempts with a jumper wire and the CEL would stay lit (no flashing)
Old Apr 11, 2013 | 01:51 PM
wwrafter's Avatar
Ok I wasn't paying attention and used the wrong terminals. Got it figured out and show no trouble codes. (Continuous flashing) and fuel pump checks out.
Old Apr 11, 2013 | 04:11 PM
wwrafter's Avatar
This should be the last update. Got everything up and running again and I feel like a fool. When the head gasket went and I decided to do an eng swap the fuel tank was getting low. Apparently too low. My GF suggested I try adding a gal or two of gas I told her that couldn't be the problem. (The fuel light wasn't even showing). Just to shut her up I opened the fuel drain plug and got a few drops of gas and a bunch of air pushing out. Oops. I guess she was dry.
In a way it was a fuel file very problem as there wasn't any fuel to deliver.
Thanks to everyone who made suggestions, I learned a couple of new tricks and I think I owe my girlfriend a candlelit dinner and a huge apology.
Crazychris1871
Jun 27, 2016 10:38 AM
aciorba23
Jun 29, 2015 04:18 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
newzingo
Jun 24, 2015 01:50 PM
