Snapped a head bolt. Afraid of snapping the bolt extractor also
Old Apr 17, 2013 | 03:53 PM
garytoyota's Avatar
I was in the process of taking the head off the block and I snapped one of the bolts. It is between the third and fourth cylinder.(22re) I drilled through the threads left in and attempted to use a bolt extractor. I have been using PB blaster on the bolt since I snapped it a couple days ago. When I used the ez out it seems like I am going to snap it out. I also tried heating up the area of the block with a propane torch before trying to extract it. Thought it might expand a bit.
Wondering if anyone has faced the same problem and how you have over come it...
Any help would be welcome.
Thanks, Gary
Old Apr 17, 2013 | 04:47 PM
slacker's Avatar
we just got a new tool in our shop http://www.babcotools.ca/Tools/Mini-...FSHhQgodmQUA9g . This is the coolest tool out there , we got the big one because of the restorations we do , I HATE rusted bolts .. and would pop that thing out like butter ..
bragging done .. everytime we have run into this , we always ended up drilling it out and re tapping the hole
Old Apr 17, 2013 | 05:40 PM
garytoyota's Avatar
Thats pretty sweet, but out of my price range
Old Apr 17, 2013 | 06:46 PM
Gizler00's Avatar
X2 on drilling and re tapping. The last 22re we just did a head on had an issue like yours and we ended up drilling it out and tapping then helicoiling with good results.
Old Apr 17, 2013 | 06:49 PM
maachine's Avatar
try not to break the easy out in there. makes drilling the bolt out even harder. i did this trying to get the timing chain cover off an old dodge engine. i had to take a punch and shatter the easy out.....then drill a bigger hole to put a bigger easy out in there. it took me a few hours and i ended up destroying the timing chain cover cause i got mad.
if you have a littlle stub sticking out. tap it lighty with a hammer for a while....pb blast....tap on it some more. that may break up the corrosion thats holding it in there.
also, try to heat the bolt directly instead of the block. the bolt will get hotter than the engine block will
Old Jun 30, 2013 | 06:59 PM
YotaWoRx's Avatar
Same thing happened to me! 2 bolts! I had some spare 14mm nuts I welded to the remaining piece and they came out!
Old Jun 30, 2013 | 08:51 PM
pascoscout's Avatar
Drilling out is best as long as your hole is straight and centered in the bolt. I use these. Www.quikcenter.com
Old Jul 1, 2013 | 02:10 PM
wyoming9's Avatar
Red face
you broke a head bolt??
Or was it one one the manifold studs or bolts??
If it was a head bolt I would be taking the block out to be able to drill it out straight and be sure to get all the chips out.
If it was a 22rec I might just get another block.
Old Jul 1, 2013 | 03:07 PM
YotaWoRx's Avatar
Head bolts! The weld a nut onto the broken stud method worked like a charm though!
kgcwb44
Jan 29, 2023 10:02 AM
adammtb
Jul 27, 2015 11:57 AM
Gone Fission
Jul 24, 2015 12:49 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
lfcarrion3
Jul 18, 2015 04:05 PM
