Mysterious spout on bottom of radiator?
Old Apr 6, 2013 | 07:23 AM
VAhunter's Avatar
So, I'm in the middle of changing the belts on my 1993 22re, and I noticed 2 spouts coming out of the bottom of the radiator. One is beside the lower coolant house and the other is beside the drain plug, should these have lines on them or not?
Attached Thumbnails Mysterious spout on bottom of radiator?-image-2679244363.jpg
Old Apr 6, 2013 | 07:48 AM
Porkchok's Avatar
Those are fittings for transmission cooler lines. Need more info on the particular truck to determine if they're necessary but I'm going to assume that if you don't see the lines dangling anywhere you're just fine. Probably not the original radiator.
Old Apr 6, 2013 | 09:16 AM
rworegon's Avatar
If you have a manual transmission, you have no need for them.
Old Apr 6, 2013 | 10:29 AM
85TurboRunner's Avatar
Yup and yup. Lots of aftermarket rads will come with them even if you specify you don't have an auto.
Old Apr 6, 2013 | 01:18 PM
VAhunter's Avatar
Yep, my trucks a 5 speed, this is how it came to me. Should I plug them or just leave them how they are?
Old Apr 6, 2013 | 01:20 PM
Alaska90's Avatar
no need to plug them. there is nothing in there but spiders.
Old Apr 6, 2013 | 01:45 PM
rworegon's Avatar
I'd cap 'em or run a hose between them so if the interface between the engine and transmission cooler fails you don't lose all your coolant.
Old Apr 6, 2013 | 01:49 PM
VAhunter's Avatar
I hate spiders...
--Oz--
Sep 6, 2015 01:06 AM
eggens
Sep 5, 2015 12:16 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
this_guy
Jul 31, 2015 01:27 PM
