22re hard to start when hot
Old Apr 20, 2013 | 11:07 PM
owbro's Avatar
I've looked through a lot of other threads dealing with this problem and I've only found one solution being a fuel pump, which I've already replaced.
If I drive it around and let it sit for a few minutes I'll have to crank it a lot for it to start. Sometimes it will start, and the rpms will jump up to 950 before it dies and I have to crank it over again for it to start and stay running.
I've replaced fpr, fuel pump, fuel filter, cold start valve, time switch, efi temp sensor, plugs, wires, cap, rotor, topped off the coolant, and replaced radiator cap.
Old Apr 21, 2013 | 06:32 AM
Stuwy123's Avatar
Check the routing of your vacuum lines. Sounds like vapor lock.
Old Apr 22, 2013 | 09:43 PM
abecedarian's Avatar
22RE? What year?
Never mind. I'm going to guess your last tune up was done compensating for cold air temperatures and you didn't bother to check the Idle Air Valve / Auxiliary Air Valve for proper operation.
Which means you didn't check out very many threads.
Old Apr 23, 2013 | 08:02 AM
fdp101452's Avatar
abecedarian, I remember a thread a while back where you had your 4runner stolen. What happened with that..........just curious.
Old Apr 23, 2013 | 09:25 AM
Co_94_PU's Avatar
Does it start right up if you crack the throttle a little? Clean the throttle body and inspect the throttle opening valve.
JF9243176
Oct 8, 2017 04:21 AM
CJ94yota
Jul 3, 2015 10:14 PM
JF9243176
Jun 24, 2015 04:53 AM
jmc88runner
Jun 18, 2015 03:39 PM
