Rebuilding manual hubs - what's involved?
Old Oct 23, 2007 | 07:57 PM
Tacoma750's Avatar
When I bougth my truck, it came with WARN hubs..BUT In a box I got two AISIN hubs. They are all in peices, and I just dont know whats what. Ide like to get them rebuilt and use them, keeping the warns for spares. Does anyone have a diagram, or SOMETHING that shows all the parts of a AISIN hub and how it goes together? Also a link to a rebuild kit would be AWSOME
Old Oct 23, 2007 | 08:05 PM
InternetRoadkill's Avatar
The Aisin hubs are rather simple. It shouldn't be hard to figure out how they go together. Just don't lose the little spring and ball.
Jay351's Avatar
When I got my aisins they where in peices in the bottom of a grease/dirty filled pan. I had never even seen aisins before!
I rebuilt them and they work perfect!
Here is the best thread I found on the subject, the pictures where the best I could find. He shows you step by step with pics what to do.
http://forum.ih8mud.com/showthread.php?t=149776
Old Oct 23, 2007 | 08:07 PM
BLKNBLU's Avatar
http://personal.utulsa.edu/~nathan-b...14freewhee.pdf
Old Oct 23, 2007 | 08:09 PM
Tacoma750's Avatar
thanks for all the help guys! IM sur eim missing parts and stuff. Time to start reading. Funny.I HATE reading, unless it has to do with my truck haha
Old Oct 23, 2007 | 08:10 PM
Prophet_MX's Avatar
HAHA I'm the same way dude! good luck on the wrenching.
Old Oct 23, 2007 | 08:11 PM
BLKNBLU's Avatar
Thats a nice write up -----> bookmarked
Old Oct 23, 2007 | 08:16 PM
Tacoma750's Avatar
is there a place I can buy a rebuild kit? Im missing MOST of that stuff haha
Old Oct 23, 2007 | 08:24 PM
BLKNBLU's Avatar
Trail Gear and Marlin have some parts. Also Downey has a complete kit. The dealership isn't a bad place for this either although you will have to piece it together.
Old Oct 23, 2007 | 08:31 PM
gametom's Avatar
i think the wabit had a kit
Old Oct 23, 2007 | 08:37 PM
Tacoma750's Avatar
Im looking at my hubs right now at the computer desk lol
Im prettty sure Im gonna need MOST of not al of the internals. Whats the little ball everybody talks about? i deffinatley dont have that
Old Oct 23, 2007 | 08:41 PM
88-surf's Avatar
this helps me alot to thanks guys
Old Oct 23, 2007 | 08:47 PM
Tacoma750's Avatar
I dont even know what im loking at here...heres a few pictures of what im looking at. The first picture is how BOTH hubs look when looking into them
this picture is what I see looing at the outer part of the HUB
This picture is the other outer part of the hub..and some other sort of real tightly wound spring
Old Oct 23, 2007 | 08:56 PM
Jay351's Avatar
Hmm It dosnt look like you are missing anything.
The "little ball" is inside the turning dial, you have to remove the snap ring on the underside of it and the red dial will sepperate from the outer ring/plate.
and dont worry about the looks of them, mine where 10x worse. Took me an hour and a half to clean them up, then another 30 mins to repaint.
If you tip your housing over, the top bigger gear should slide out.
the spring pictures to the right on the 3rd pic snaps into the gear, wich connects to the spring on the dial.
And the notches on the plate attached to the wound spring on the handle need to secere into the dial.
If you compress the spring you will see the notches fit into grove on the dial, the spring needs to be compressed.
Old Oct 23, 2007 | 08:58 PM
Tacoma750's Avatar
hmm..ok. If you look in th elast picture i posted..what is the spring on the right? the real tight one
Old Oct 23, 2007 | 08:59 PM
BLKNBLU's Avatar
Look at the link that jay351 sent you. Pic #3 in post #3 shows the ball. You can't see the spring cuz it's under the ball in a hole/slot in the dial. It looks like your face and dial are still assembled (held together with a snap ring) Be careful disassembling it as the spring and ball have a tendency to go flying when you seperate the parts.
Old Oct 23, 2007 | 09:00 PM
Tacoma750's Avatar
how did you remove that snap ring that hold sit all together?
Old Oct 23, 2007 | 09:02 PM
Jay351's Avatar
Yes If you look in that thread it will show exactly what goes where.
But that spring attaches to the end of the big spring little flat thing at the end. Then the little spring threads into the big gear making one unit.
When things are assembled you should have 2 parts. the housing and gear and the dial/springs/gear
If you have much problems, post up plently of pictures, I can guide you where to put what. And anyone else who wants to help.
Old Oct 23, 2007 | 09:03 PM
Jay351's Avatar
Get a set of snap ring pliers, I got a nice set thats reversable at home hardware for under 10 bucks
Old Oct 23, 2007 | 09:04 PM
BLKNBLU's Avatar
Snap ring pliers
