Leaf spring bushings for steering idler arm repair.
Old 10-26-2007, 11:58 AM
tibbycruiser's Avatar
I had to replace my stock idler arm on my 88 4runner so i took it off and noticed the bushings were worn, I didnt have my new idler arm yet so I started tinkering in my garage I pulled it apart and noticed the bushings looked about the same size as spring bushings. I had a box of urethane bushings from my landcruiser sitting around. They were tight but worked perfectly.
Summary:
If you have some leafspring bushing and your idler arm bushings are shot it think the urethane bushings work great.
Old 10-26-2007, 12:18 PM
MudHippy's Avatar
Waste not want not.
That's why I keep all kinds of crap like that sittin' on shelves. All I got for spare bushings currently are some idler arm bushings, coincidentally, and some shock bushings.
I won't likely be needing the idler arm bushings, as I use manganese bronze bushings in mine.
That's a good trick to know though, thanks for sharin'. I wouldn't bother tryin' to use rubber bushings if that was what ya had. But urethane just might actually last ya awhile.
Old 10-27-2007, 02:23 PM
n4ynu1010's Avatar
Summary:
HEHEHE
nvdesertrunner
05-11-2020 08:18 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
shisha1999
09-21-2015 08:22 PM
88sasturbotoy
08-11-2015 01:56 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: Leaf spring bushings for steering idler arm repair.
