4wheelDrive
Old Oct 28, 2007 | 12:07 PM
Justinvd's Avatar
4wheelDrive
1988 4runner, 22R-E Automatic
When i am in 4low and wheeling my truck really doesn't like to stop. Even with the brake full on it starts to vibrate really bad and try to push through it, i recently did a complete brake job. Rear = New pads, drums, brake cylinders. Front = New Calipers and Rotors. Also replaced master cylinder. But yeah any ideas on this would be great thanks in advance.
Justin
Old Oct 28, 2007 | 12:13 PM
superjoe83's Avatar
what is your idle speed?
Old Oct 28, 2007 | 12:21 PM
Justinvd's Avatar
Not sure, it does seem to idle pretty high though. Should i adjust this?
Old Oct 28, 2007 | 12:45 PM
nix4x4's Avatar
adjusting idle speed would at leastbe a start. It should be done anyway, and might fix your problem, too. Not sure what spec is for a 22RE, though.
Old Oct 28, 2007 | 01:13 PM
88-surf's Avatar
dose your auto have a rpm counter?? should be 600 rpm on idle
Old Oct 28, 2007 | 01:24 PM
DeathCougar's Avatar
Rpm Counter? Must be a foreign word lol. We call it a Tach or Tachometer here haha
btw you should never ever have to adjust the idle speed. They are set from the factory. If its idling high, you have another problem that needs to be addressed.
Old Oct 28, 2007 | 01:25 PM
superjoe83's Avatar
but who's to say that someone hasn't messed with it in the past?
Old Oct 28, 2007 | 01:51 PM
Well that is possible, but if someone has already messed with it, you may have a hidden problem that is now showing itself.
Old Oct 28, 2007 | 02:05 PM
Jeenyus04's Avatar
600 hundred seems a little low. I'd say more like 750 or so. Also are you sure you bled your brakes good when you replaced all that? With weel cylinders, calipers, and master cylinder you could have air in you entire system.. I'd make sure those are bled well, and if you have access to a vacum bleeder or pressure bleeder use those as that will save you some time. just my .02 cents
Old Oct 28, 2007 | 02:13 PM
According to my 89 4Runner V6 automatic, idle is 800rpm, my 86 22RE 5sp is 750.
Old Oct 28, 2007 | 04:06 PM
88-surf's Avatar
thats because yours is a v6. my 2lt is 600 and that is what it should be according to what my dad said hes an ex drag car builder and he loves his cars so yea i trust him lol. just try it and if it don't work then raise it.
