new Gauge HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 29, 2007 | 10:06 AM
Belize Off Road Team's Avatar
Exclamation new Gauge HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
while installing my new reverse halo gauges on my 91 Surf, i ran into a issue. while placing the new speedo over the old, the needle popped off! so i called parkcity TOYOTA in Medicine Hat AB Canada, and they said it should not be a problem, so i put the needle back on and now it goes a LOT lower than just below 0 where it should be, it nw hangs out of the frame of the speedo, what the H E L * do i do now? PLEASE tell me i dont have to order new cluster! please if you have encounterd this problem, pm me with a solution.
Old Oct 29, 2007 | 10:12 AM
Old Oct 29, 2007 | 10:29 AM
needsomecam's Avatar
take the needle off, put the truck in gear and while stopped with your foot on the brake put the needle on so it points to zero.
Old Oct 29, 2007 | 03:11 PM
run4her's Avatar
i got my friend to drive 30 and i matched his speed then put the needle back on and my speedo is right on.
Old Oct 29, 2007 | 03:15 PM
OSU4Runner's Avatar
x2....might take a few times to get it right
Old Oct 29, 2007 | 06:45 PM
slosurfer's Avatar
you didn't bust off the stop post did you?
Old Oct 30, 2007 | 01:37 PM
no, i got it now, i just did what run4her did, its good now.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
dbollier123
Sep 29, 2015 05:23 PM
