Weird bogging while engaging clutch
Old Oct 26, 2007 | 06:16 PM
Guardian_Saint's Avatar
Recently after the timing replacement I am having this bogging issue while trying to go on 1st gear but is very noticeable at 2nd gear, alittle bit on 3rd gear and none at 4th & 5th gear. I have everything in correctly order and timing it at 10 degree, spark plug wire 1 year ago, chenge spark plugs 5 months ago. When it is in neutral it rev at no problem w/o bogging like in gear. I know it doesn't look normal cause I know the normal for a clutch to bog down a bit but not like this, it felt like the piston had stop for 3 second, causing it to died then back to live again, after that it rev fine. Whats the ordeal of this, I'm thinking TPS adjustment needed? thanks in advance.
Old Oct 26, 2007 | 06:29 PM
n4ynu1010's Avatar
I think that would be a good place to start if everything else is good , you have the walkthrough for that ?
Old Oct 26, 2007 | 06:50 PM
I am searching for it, found one that may guide me through it, I am just giong to do it the way he done on his, adjust it with the yellow mark indicated on his picture shown on his thread, thanks n4ynu1010, I will start from there.
Old Oct 26, 2007 | 06:53 PM
n4ynu1010's Avatar
Tps
Originally Posted by Guardian_Saint
I searching for it, found one that may guide me through it, I am just giong to do it the way he done on his, adjust it with the yellow mark indicated on his picture shown on his thread, thanks n4ynu1010, I will start from there.
Here is a good walkthrough :
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
and here is the one from FSM :
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
Daenerysdad
Oct 1, 2015 07:33 PM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
May-39
Sep 6, 2015 01:05 PM
Nick Berg
Sep 3, 2015 04:36 AM
