AC swap from 22RE to 6cyl 3VZE can it be done?
Old 10-23-2007, 11:51 AM
cchinny's Avatar
Can the AC system from a 22RE be swapped into a 6cyl 3vze truck? Any help appreciated. What parts if any are interchangable?
Thanks in advance!
Old 10-23-2007, 11:54 AM
cchinny's Avatar
AC Swap
FYI if a swap is possible, I may be getting a 85 SR5 PU for the cost of a couple parts!
Old 10-23-2007, 12:10 PM
Willcipher's Avatar
Sort of but not completely. Every part of the system that is attached to the body (condenser, evaporator assy, receiver/dryer and ridgid lines are the same. The flexible rubber hoses to the compressor, the compressor mount and the compressor itself are all different. Also, the VSV idle up is unique to the each motor. The wiring in the dash should be the same. Obviously, the compressor clutch wire is different. It would be in your best interest to grab the complete system from the exact same model and engine. FWIW, the early 4Runners and trucks had different condensers. The 4Runners have an additional layer at the top- maybe to compensate for the larger cooling area?
Old 10-23-2007, 04:10 PM
cchinny's Avatar
Thanks for the info!
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
deepmarsh
08-06-2015 03:44 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: AC swap from 22RE to 6cyl 3VZE can it be done?
