Steering Wheel mis-aligned
Old Oct 25, 2007 | 03:00 PM
toyotadan's Avatar
Hey guys... just had someone work on my truck the other weekend (Was fixing clutch bracket... he had removed the dash to look around). i got it back, and the steering wheel is now almost upside down when im driving. It still drives straight, and corners well... just wondering how it could have got like this? Anything to worry about?.... he mentioned that he "Had a hard time moving around inside the truck by the steering wheel". Yet, he didnt mention that he had done this....
Thanks
Dan
Old Oct 25, 2007 | 03:11 PM
rdlsz24's Avatar
It's not too hard too pull the steering wheel off and align it properly.
Rob
Old Oct 25, 2007 | 03:27 PM
sh0kk86's Avatar
i just pulled mine off yesterday to put on a new wheel, and i dont think i got it dead on, gonna pull it off and put it over a tooth or two.
pop the cetner cap off, or remove the screws at the lwoer end of the wheen on the back, and just use an 18mm? socket/torque wrench and get that nut loose. use a puller if it wont come out, but sicne it was recent, it should pop out, and just move it upside down.
make sure to have the tires straight when you park it.
Old Oct 25, 2007 | 03:28 PM
toyotadan's Avatar
Rob
Sweet.... Ill look into that then. Never dealt with this before...
Thanks
Dan
aviator's Avatar
Very easy to fix... the horn button comes off with one or two Phillips heads screws then disconnect it. The steering wheel is held on by the big nut just unscrew it and you can wiggle the steering wheel off... or you can go buy/rent a puller in which case thread the puller bolts into the two threaded holes either side of the large nut [after removing it] then position the puller bolt against the dimple in the end of the steering shaft and crank away...
but you really don't need the puller in my experience.
Hope this helped aviator
Old Oct 25, 2007 | 03:44 PM
MudHippy's Avatar
Originally Posted by sh0kk86
...and just use an 18mm? socket/torque wrench...
19mm for that one...but always 17mm or 19mm...no 18mm on Toyota
Old Oct 25, 2007 | 04:47 PM
sh0kk86's Avatar
meh i tried banging on it yesterday and couldnt get it os i just threw the nut on there, and drove down to autozone, rented the puller for $16, and within a half hour was returning it and getting my money back.
Old Oct 25, 2007 | 07:21 PM
twister6er's Avatar
Just a little advice, if you are going to do it without a puller, leave the nut on the last thread or so when you try to get it off, or just wear a helmet.
Old Oct 26, 2007 | 05:32 AM
aviator's Avatar
Where's the fun in that?
Up&Down
Aug 11, 2015 10:04 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 1, 2015 01:55 PM
terminator
Jul 27, 2015 07:13 PM
