I have $2000 for a engine swap.
Old Oct 29, 2007 | 04:09 PM
likewh0a5's Avatar
I just spun a rod in my 3.0L engine and I've decided to swap it with a 4.3L Vortec, carborated engine. Any suggestions and advice on where to purchase the motor, transmission adaptor plate and 500... EdleBrock Carberator. I'm planning to keep the stock transmission for now, until I can find an automatic for the right price. I am also going to do a solid axle, leaf spring conversion to the front end. Any advice and suggestions will be greatly appreciated.
Old Oct 29, 2007 | 09:55 PM
olharleyman's Avatar
Don't get me wrong but I was gonna do the CHEVY swap and buy the time I found all the you got to get for it it just seems way more sensible to do the 3.4 toy swap.
But if you feel that the Chevy swap is the only way to go then DOWNEY OFF ROAD is a good place to start. Call them and talk with them and find out how much is involved and how much it will cost.
If I remember correctly it was almost 4grand for all the parts needed and you can end up doing the running gear as well because the Chevy power can be to much for the rears and transfer case not to menchin the tranny. The big thing is you don't want carbed you want e.f.i. (this from a old school motorhead) just the angles you encounter on the trail can get the carb to empty the bowl and you have no fuel.
I have a 400 hp 327 I wanted to do the same thing with but in the long run your better off with the 3.4 yota motor.
Just from the money stand point you would save it's worth it. Just my .02 cents
Old Oct 29, 2007 | 10:08 PM
apalmer1's Avatar
Why a carbureted 4.3? Get a newer one, i am in the process of rebuilding one right now, its got the TBI (throttle body injection) but even it only makes 155hp in stock form, my buddy has a newer 4.3 with the MPI in his S10 and that thing makes a little over 200hp in stock form and it rips. Though the 3.4 in my truck comes pretty close in power with a LOT better MPG.
Old Oct 29, 2007 | 10:47 PM
Luvmeye22re's Avatar
Get a TBI, you won't get hit much harder at a yard for the wiring/ecu and the reliability/driveability/economy will be SO worth it. And if you have the money for the SAS etc. you can spare another 100 or so for a TBI engine...
Old Oct 30, 2007 | 06:15 AM
MonsterMaxx's Avatar
Been down this research path myself...
NWOR has swap parts too
And don't forget Advanced Adaptors
There's also another big shop that makes stuff, but I can never remember their name, Google will find it for you
Old Oct 30, 2007 | 07:06 AM
here you go:
http://www.pirate4x4.com/forum/showt...ghlight=toyota
Old Oct 30, 2007 | 07:17 AM
Tacoma750's Avatar
Ya know..I have the buick 3.8L in my yota pickup. Its the older one, with the carb. I wish it was fuel injected :-( Im actually looking now at swapping in a newer fuel injected 3.8L.
Old Oct 31, 2007 | 12:51 PM
Firebb15's Avatar
I could be wrong...but im pretty sure the vortec 4.3 is fuel injected, unless you slap a intake and carb on it. My 92 sonoma is a non-vortec motor and it even has TBI.
Old Nov 9, 2007 | 10:21 AM
likewh0a5's Avatar
Tbi?
I was wondering what a TBI stands for. I'm still new to this. I just picked up a 4 cyl. from the junk yard for $250. I have found that there are loads of upgrades for this motor. I'd need to find a transmission now, unless the bell housing will bolt up to my 3.0 Transmission. Does anybody know if they bolt up without an adaptor?
Old Nov 9, 2007 | 10:26 AM
Cyberman's Avatar
Usually, TBI=Throttle Body Injection
Old Nov 9, 2007 | 01:48 PM
likewh0a5's Avatar
Thank you. Can a 22R transmission's bell-housing bolt up to a 3.0L transmission?
mskalmus
May 28, 2017 07:51 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
