Diagnose Me!
Old Oct 27, 2007 | 01:54 PM
GoldenBeaR6's Avatar
Diagnose Me!
Brand new to me '95 pickup, 4x4, 5spd., 22RE.
Changed the oil today, level and color looked good. Then, I checked the coolant - brown, brown brown. The level was all the way to the top with a little in the overflow tank. I think it was oil because it had a little rainbow on the top. No smoke or other signs of bad head gasket.
Any thoughts?
Chris
Old Oct 27, 2007 | 02:00 PM
ydopen's Avatar
Drain it- flush it -and refill it and run it for about a week then see whats up.
Old Oct 27, 2007 | 02:12 PM
I drained it, flushed it, refilled it. I'll keep you posted.
Old Oct 27, 2007 | 02:32 PM
gilby4runner's Avatar
have you blown a HG in the past? A friends 94's coolant looked like crap due to not having flushed the radiator after a blown HG... just a thought
Old Oct 27, 2007 | 06:05 PM
OSU4Runner's Avatar
x2!!!
Old Oct 27, 2007 | 06:26 PM
frodin1's Avatar
It may just be rust junk from never being changed.
Old Oct 27, 2007 | 07:30 PM
javadoody's Avatar
isn't the color of the stock toyota coolant brown? if so, a little radiator rust with that should account for it.
Old Oct 27, 2007 | 08:21 PM
86tuning's Avatar
Stock coolant is red.
Milky coolant (like too much cream in your coffee) or milky oil = coolant/oil mixing.
This is from either:
1. head gasket
2. timing cover failure (from a failed waterpump, etc)
Old Oct 28, 2007 | 12:25 AM
My stock coolant is green. Switch to red was later.
What's the best way figure out which problem it might be?
Compression test, coolant pressure test, prayer?
shisha1999
Mar 3, 2016 07:09 PM
smilen724
13
Nov 8, 2015 04:11 PM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
