diesel in a '92?
Old Oct 25, 2007 | 10:11 PM
nix4x4's Avatar
diesel in a '92?
I was wondering what the best diesel motor for a 3rd gen pickup would if i were considering a motor swap. I would really like it to be a six cylinder but i know that space is limited in our trucks. Just lookin for some opinions
Old Oct 26, 2007 | 08:41 PM
nix4x4's Avatar
Nobody wants to touch this one, huh?
Old Oct 26, 2007 | 09:24 PM
camo31_10.50's Avatar
idk how much room...or how difficult it would be to do this swap into a 3rd gen...but if i were you i would spend the money..and go for a Cummins 4BT..up to 27mpg.....up to 160hp..400FT LBS OF TORQUE....amazing for a 4cyl...would be a nice engine though...if i ever do a motor swap it will be a Cummins 4BT...
Old Oct 26, 2007 | 09:37 PM
WCorbett's Avatar
it wont pass smog and I know diesels dont have to be smogged but its registered as gasoline so u would have to smog it.
jfreisner's Avatar
these links might help...
http://toyotadiesel.com/forums/
More specific: http://toyotadiesel.com/forums/showthread.php?t=2502
https://www.yotatech.com/forums/f2/t...inished-13098/
Old Oct 26, 2007 | 10:16 PM
Snipes4ever's Avatar
The truck in the second link is sweet, i want a deisel so bad.
Old Oct 26, 2007 | 10:30 PM
nix4x4's Avatar
This is going out on limb, but I had a crazy thought. Is there any way the you could mate a Cummins 4BT with, say, a tractor transmission? One with like 8 forward gears and 4 reverse? Always thought that would be the most kick ass setup ever
Old Oct 26, 2007 | 10:32 PM
jfreisner's Avatar
Search toyotadiesel.com, I think I saw a thread about a 1-ton project....1-ton engine, 1-ton running gear, ect.
EDIT, here's the link. I haven't read the thread so I dont know if its an actual project or not...
http://toyotadiesel.com/forums/showthread.php?t=3965
Old Oct 27, 2007 | 04:01 AM
Robert m's Avatar
thats why you would take it to a smog ref and have it inspected and switched over to a diesel in the DMV system.
Old Oct 27, 2007 | 11:57 AM
nix4x4's Avatar
By the time it will see any modification as major as this one it'll be an untagged, uninsured off-road only vehicle so I'm not really worried about smog. Plus, Ohio did away with it last year thank god or my truck wouldn't pass it as it sits now
Old Oct 27, 2007 | 12:02 PM
n4ynu1010's Avatar
Emissions Testing Bad Bad Bad
Old Oct 27, 2007 | 12:11 PM
Belize Off Road Team's Avatar
believe it or not, toyota made some neat little motors over 25 years ago that would be aloud in the states.
Old Oct 28, 2007 | 08:15 AM
nix4x4's Avatar
How difficult would it be find an old toyota diesel in the states? Also, what are the chances of one of them fitting up to an R150F?
Old Oct 28, 2007 | 08:33 AM
jfreisner's Avatar
These guys really know what they're doing, I'd go to them for answers...
http://dieseltoyz.com/Home.html
Old Oct 28, 2007 | 08:21 PM
WCorbett's Avatar
is that possible to switch it over to diesel in registration? hmmmm plans in my future.
Old Oct 28, 2007 | 08:23 PM
tc's Avatar
tc
A guy on the Marlin Crawler forums swapped in a VW TDI ...
Old Oct 28, 2007 | 08:37 PM
i know that the 4bt cummins can be put into ANY FJ cruizer...idk about the 3rd gens...but my dad and I are thinking about putting a 4bt into my 1st gen P/U...i know it takes a 4in lift just to fit that puppy in there...other than that....its all pretty simple...and turn a few screws...and u can 160 hp..and 400 lb ft of torque...(frame twisting torque for my 1st gen)
Old Oct 28, 2007 | 09:30 PM
nix4x4's Avatar
That would be sweet. Camo, what where you thinking for a transmission/transfercase.
Old Oct 29, 2007 | 03:44 AM
82yota's Avatar
I have a Toyota turbo diesel in my 92 pickup. Just finished putting it in last week. Its a 4 cyl turbo diesel. 3.0L. Don't let the 4 cyl thing fool you this thing goes. And is not hard on fuel either. I get about 100 miles before the needle moves off full. I figured it out and I am getting 30 mpg US. And I haven't put the 4.10 gears in it so it is revving too high right now. I got the motor from www.jarcoinc.com . Also this motor was designed to go in the Toyota truck and runners. And if you get the standard tranny they came with the R150. So you could use yours but would just need to change the bellhousing. The motor I have runs great and has lots of power. Much better than the 3vze my dad has. And mine is an auto. And the 3 inch straight pipe right from the turbo sounds pretty mean. Not noisey but just mean.
Old Oct 29, 2007 | 08:42 AM
nix4x4's Avatar
82Yota thats awesome. What engine model is that? What kind of boost you running?
