help-too much pressure
Old Nov 1, 2007 | 09:57 AM
j's Avatar
j
When i got home yesterday the engine light came on and when i stopped coolant was coming out of the cap. all the hoses were super pressurized. truck is running fine. no white smoke. thanks
oh yah 88 4runner v6
Old Nov 1, 2007 | 10:33 AM
needsomecam's Avatar
either you really overheated or you got a blown headgasket. most likely the HG. but to be sure wait till it cools down and then take the cap off and start the truck if it bubble its a blown HG. and you could do a compression test too see how bad its blown.
Old Nov 1, 2007 | 10:39 AM
SEAIRESCUE's Avatar
Probably HG. They often fail between the cylinder and a water jacket. That pumps exhaust pressure into the cooling system. As suggested, look for bubbles when you refill and if suspect, do a system pressure test.
Old Nov 1, 2007 | 10:49 AM
j's Avatar
j
just found a small hole in one of the hoses, could this be the cause?
Old Nov 1, 2007 | 11:03 AM
severely doubt it but you are going to replace it anyways if you do some engine work.
Old Nov 1, 2007 | 03:05 PM
dcg9381's Avatar
Unlikely, unless you overheated and boiled your water, but worth a try.
Watch for smoke on start up. If you blow into the water jacket, you might not have any smoke during driving - but the radiator pressure will push water into the cylinder and sometimes cause smoke on start up.
ashamsuddin
17
Jul 22, 2024 03:59 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
voiddweller
Sep 28, 2015 11:21 PM
charlie_fong
Sep 27, 2015 10:06 PM
