THIS is a stupid question....cooalnt for radiator?
Old Oct 30, 2007 | 09:32 PM
Tacoma750's Avatar
Well before winter im gonna drain my coolant and refill it. PLUS I dont know the last time it was done (dont know how the PO took care of the truck) here is my question..
I have a buick 3.8L motor, with a toyota 4 cylinder radiator. What coolant should I use? Do I use half water and half coolant? I have never flushed a cooling system, so i dont know how to do it, or what to refill it iwth. HELP woudl be great.
Old Oct 30, 2007 | 09:33 PM
Jay351's Avatar
Go to the stealer and get TOYOTA coolant. Go 50/50 with DISTILLED water.
Old Oct 30, 2007 | 09:34 PM
Tofer's Avatar
Sponsor
or just pick up whatever's on sale at autozone and use the garden hose.....
but yes 50/50 as best you can.
Old Oct 30, 2007 | 09:39 PM
thook's Avatar
You could get one of those cheap, little back-flush Prestone kits at the part store. Hook the hose adapter into the heater hose and flush with a garden hose until it's clear. It works pretty good.
Old Oct 30, 2007 | 09:42 PM
stormin94's Avatar
Are you really supposed to change that? Seems like a waste of time to me.....it still works, it's not dirty, and it doesn't leak, so why bother?
Old Oct 30, 2007 | 09:43 PM
Tofer's Avatar
Sponsor
or once again stick the garden hose in the upper and lower hose to flush the radiator. and hten pull the t-stat, and flush the block the same way... then replace the t-stat since its out.
Old Oct 30, 2007 | 09:44 PM
thook's Avatar
Supposed to change what...the coolant? You must be joking.
Old Oct 30, 2007 | 09:45 PM
thook's Avatar
Originally Posted by yota4runna
Use the garden hose UNLESS you're on a well. Don't put well water in your radiator or battery.
You must have a well, too.
Old Oct 30, 2007 | 09:48 PM
Jay351's Avatar
Yes, after awhile coolant becomes acidic and will eat away at metals. Like your radiator for instance.
Old Oct 30, 2007 | 10:05 PM
stormin94's Avatar
How often should I change it?
Old Oct 30, 2007 | 10:08 PM
Jay351's Avatar
once a year or two is good
Old Oct 30, 2007 | 10:13 PM
thook's Avatar
OH! You weren't kidding. Sorry. Yeah man, the coolant's a good thing to change regularly.
Read'm article...
One failure mode associated with dirty coolant is known as electrolysis. Electrolysis occurs when stray electrical current routes itself through the engine coolant. The electricity is attempting to find the shortest path, and impurities in the coolant often generate a path of least resistance that the electricity travels across. The source of this stray electricity is often from electrical engine accessories which have not been properly grounded. A missing engine or transmission ground strap can also cause the coolant to become electrified. Sometimes the path of least resistance becomes a radiator, a heater hose, or even the heater core. These components are often well grounded, and offer a ground path from the engine to the chassis by means of the semi-conductive path of the coolant.
The rest of it..
http://www.drivewerks.com/Newsletter/vol-7.htm
Old Oct 30, 2007 | 10:19 PM
apalmer1's Avatar
Yep yep, good preaching, you can tell some radiators have run the same coolant for far too long, the paint will begin to erode off the radiator, and you dont even wana know what it makes the components under the valve cover look like if it gets really bad
Old Oct 31, 2007 | 12:19 AM
stormin94's Avatar
Thanks
Old Oct 31, 2007 | 07:24 AM
jcfb's Avatar
You can pick up a Prestone radiator flush at the local AutoZone. You drain the radiator, put the bottle in, fill the rest up with water, and drive it around at operating temp for 10 minutes. I did that to mine, as well as several other vehicles. I would then drain that, stick a hose in the top of the radiator, undo the drain and just spray until everything looks clean.
I use distilled water to fill my radiator. You can pick a gallon of it up at your local gas station for about $3.
Old Oct 31, 2007 | 08:26 AM
Greg_Canada's Avatar
And DO NOT mix red + green coolant! under ANY circumstances! it will milk-ify and turn to sludge
Old Oct 31, 2007 | 08:28 AM
thook's Avatar
I take it that's from experience...lol. That would suck.
And by red, what brand do you mean? It's ethylene glycol based, isn't it?
Old Oct 31, 2007 | 08:31 AM
Tacoma750's Avatar
so i just pull that drain at the bottom of the radiator? or is there something on the engine I have to drain aswell? I have NO CLUE about this. I guess someone said to pull the tstat...do i HAVE to do that
Old Oct 31, 2007 | 08:34 AM
Oh i didnt do it myself, but my cousin sold his taco, 2 days later gets a call, the dumb**** put the wrong coolant in and blew the headgasket... of course we didnt find that out till later....
Old Oct 31, 2007 | 08:48 AM
Tacoma750's Avatar
Also...should I use just antifreeze? since its winter now and it gets cold. Is there a differance between antifrezxe and coolant?
