What is this valve?
Old Oct 27, 2007 | 07:58 AM
Skinamer's Avatar
What is this valve?
I cant find anything about it in my FSM. It screws into the upper intake plenum on my 22RE. What's it called? What does it do? Can I clean it out with carb cleaner? It has an adjustment, how do I adjust it properly and know it is working properly? Thanks guys.
Old Oct 27, 2007 | 08:08 AM
thook's Avatar
It's the A/C idle valve
https://www.yotatech.com/forums/f116...ve-fix-103923/
Old Oct 27, 2007 | 08:30 AM
Skinamer's Avatar
Well my A/c doesnt work right now anyways. The bearings in the pulley are locked up. So As long as the a/c is not running this valve does nothing, right?
Old Oct 27, 2007 | 08:43 AM
4Crawler's Avatar
If you have power steering, it also bumps up the idle when you try turning the steering wheel when stopped.
Old Oct 27, 2007 | 11:23 AM
Skinamer's Avatar
so will it hurt to clean it out with solvent to get the carbon build up out?
Old Oct 27, 2007 | 11:28 AM
4Crawler's Avatar
Should not hurt anything. You can test it to make sure it is working by applying vacuum to the small fittings and see if it opens and closes.
Old Oct 27, 2007 | 11:48 AM
n4ynu1010's Avatar
Leave it there(if you take it off just store that puppy) , may need it one day if you have your A/C fixed
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
